That's likely a display mesh approximation limitation, if you export it (with a forced divided larger than at 2 or less), those arcs seems correctly evaluated.
You can change the mesh angle display in the display option, but even with a tiny angle it wont be as good as the mesh export.
Also if you want a more accurate display, you can maybe rebuild the arc (rebuild command here with 10 points), that should trick the mesher.
(I'm not sure if you still have a perfect math arc doing so ?)
Hi sos,
I have been a Firefox user and member of the Moi3D forum for many years. I have never encountered any problems when communicating, or when sending images or files as attachments. I therefore don't think the problem is with Firefox.
