Joined curve extrudes as rectangle
All  1-6  7-13
11876.7 In reply to 11876.6
Hi sos, if you get another case where it's not working as expected please post the .3dm model file here or e-mail to moi@moi3d.com so I can take a look at it.
Thanks, - Michael
11876.8 In reply to 11876.7
My problem posting images is Firefox. There, when composing a reply I only have three buttons: Post Preview Cancel.
I have switched to Vivaldi, where I also have the Attachements button. Someday soon I'm giving up on Firefox.
I did a set of different radius curves (attached). For shallow curves, the curve is ignored. Deeper curves and I get a straight approximation to the curve (in the solid). 3dm attached.
Size: 93.6 KB, Downloaded: 31 times, Dimensions: 1285x1203px
11876.9 In reply to 11876.8
That's likely a display mesh approximation limitation, if you export it (with a forced divided larger than at 2 or less), those arcs seems correctly evaluated.
You can change the mesh angle display in the display option, but even with a tiny angle it wont be as good as the mesh export.
11876.10
Also if you want a more accurate display, you can maybe rebuild the arc (rebuild command here with 10 points), that should trick the mesher.
(I'm not sure if you still have a perfect math arc doing so ?)
11876.11 In reply to 11876.8
Hi sos, yes like PaQ writes above that's just a display artifact. It's best to just ignore it.
Also some previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10950.2
11876.12 In reply to 11876.11
This makes tons of sense. Thank you.
Steve
11876.13 In reply to 11876.8
Hi sos,
I have been a Firefox user and member of the Moi3D forum for many years. I have never encountered any problems when communicating, or when sending images or files as attachments. I therefore don't think the problem is with Firefox.
- Zooen
Show messages: All  1-6  7-13
