Sliders for values
All  1-4  5-8
11867.5 In reply to 11867.4
For the blend function, I don't remember going anywhere far from the default value (0.5 - 1.5 ish) ... but anyone has different usage.
Maybe a way to slide the tension directly in the viewport (LMB + drag ?) could match other direct operation (like the fillet radius control) ? ... not sure about the side effect implication.
11867.6 In reply to 11867.4
Hi Phiro,
> What is you opinion about this request ?
Well it looks like a rather large control. It would probably be difficult to expand every input field to be so wide.
The current UI is expecting input fields to be more compact than that because they need to fit within the side pane along with a text label and units label like this:
Perhaps a slider could be added hidden and when you push a small button near the numeric field could switch unhide/hide the slider ?
Just an idea...
11867.8 In reply to 11867.7
Hi Phiro,
> Just an idea...
There is something similar to that - the numpad that pops up when you click on a field.
Maybe a slider could actually go on the numpad, since that goes into its own separate flyout window it could have wider stuff in there.
Show messages: All  1-4  5-8
