Michael's Plasticity rants
 1-9  …  50-69  70-89  90-99
11865.90 In reply to 11865.89
You don't need to change constraints. Unless you want certain dimensions of the part to change. In which case you will be very glad that those constraints exist.
NX is CAD+CAM, TeamCenter is PLM.
11865.91 In reply to 11865.90
"""""""""""""Unless you want certain dimensions of the part to change. In which case you will be very glad that those constraints exist.""""""""""""""
My design abilities and artistry just shriveled up into a black, dead ball of tar on the end of my pencil....
Hard Pass.
I'll pass my models to the engineer who is well schooled in NX.
11865.92 In reply to 11865.90
""""""""""NX is CAD+CAM, TeamCenter is PLM""""""""""""""
Formerly known as Unigraphics, it is often referred to as "Siemens PLM NX" due to its origin and connection with Siemens Digital Industries Software.
The fact they forked it down is just sales and marketing. All the complaints about "$30,000 for a bunch of stuff i dont need!"
Now you can buy smaller chunks of stuff for less money......
You can even buy "Nicks Version" for 200 bucks!!!
11865.93 In reply to 11865.91
I guess we have to agree to disagree on the utility/necessity of 3D constraints then.
3D constraints as I mean them are different from classical 2D sketch constraints. Not only in the obvious aspect of being defined on 3d geometry, not sketch level but those are more meant as an expression of design intent, telling the direct editing software which aspects are important (so what not to "accidentally" change when pulling somewhere) and what to change from how it is to how it is supposed to be (by adding a new constraint and changing it's value). This requires a lot more implicit "understanding" from the system as it is more about finding the solution for an underspecified system (full explicit specification would require a fully constrained body), filling in the gaps with most likely intention of the designer: "Make it like now, "just" that section 10 cm instead of 7 cm". A human would usually immediately know how the result should look like and if 999 out of 1000 would come to the same conclusion then this is most likely a well defined transformation. One based on implicit knowledge. Certainly not easy. But there are direct modelers that can do this pretty convincingly (NX, SE, Ansys etc.) so it seems to be doable.
Sorry for starting to derail "Michael's Plasticity rants" :)
EDITED: 5 Jan by NAN
11865.94 In reply to 11865.93
“”””NX-Ansys-SolidEdge, etx”””””””
Already do all that…. Nothing new. Very accomplished at it. To aspire to jump into THAT pool is, not very visionary.
Hardly MoI and all the groundbreaking innovation from Michael…..
11865.95
Hello,
Blender is a UX dumpster fire so it tracks that users in that demographic would be forgiving when it comes to usability.
Plasticity's persistent limitation will be its UX, that's a huge drag that MoI doesn't have.
The argument could be made that Fitts applies less since you could execute many commands via keyboard without moving the cursor, but then Hicks and Miller would like to have a chat with you. The cognitive load required to operate Plasticity is really up there.
At the end of the day you have to remove the reasons for someone to use the other product. If it's a useful feature that doesn't exist in your product, work to implement it better than the competition ever could. Identify the weaknesses in the competitors product and put a spotlight on it by improving and refining your better feature, nothing speaks like putting operations under a stopwatch.
Interestingly, where the chamfer command doesn't work in P3D the bridge surface command usually does. I did experience a hard crash when defeaturing a part in P3D, but when I closed and rebooted the app it brought the file back to the moment before the crash. That said I've experienced more crashes in P3D in 2 months than I have since MoI 1.0, can't beat the reliability of MoI.
11865.96 In reply to 11865.95
Hi OSTexo, re: Plasticity crashes -
So with an app that hasn't been around that long you might be thinking that it just needs more time for crash bugs to come to light.
But the crashes I documented above are not crashes in Plasticity's own code, those are a crash in the Parasolid kernel.
Parasolid was launched in 1986, 40 years ago!!
It's strange that I can poke it for 30 minutes and run into a crash on simple geometry.
11865.97 In reply to 11865.24
"Apple has pushed far in that direction recently as well"
Amen!!!!
11865.98 In reply to 11865.97
And Michael's next statement is equally good:
> I find it distasteful when I see poorly designed UX being praised.
I appreciate MoI's UX elegance and contentedly use it with only the most minor modifications, specifically: CombineSidePanePalettes since I'm on small laptop and Extras to help keep track of the various scripts.
https://moi3d.com/forum/index.php?webtag=MOI&msg=10368.1
https://moi3d.com/forum/index.php?webtag=MOI&msg=10353.1
--Larry
11865.99
Hello,
Do the geometric modeling kernel developers really have any significant motivation at this point to measurably improve the quality of their product? It doesn't seem like it, very few options to choose from.
Show messages:  1-9  …  30-49  50-69  70-89  90-99
