Michael's Plasticity rants
 1-11  …  32-51  52-71  72-91  92-99
11865.72 In reply to 11865.69
@ PaQ, <...sigh...> "just as good, sometimes better" he claims.... ????
I would like to see any actual examples of that.
In reality I don't think I have seen even a single case where the Plasticity n-gon tessellation was better than MoI's .
If you're lucky, with certain kinds of models it can only be slightly worse.
On more complex models Plasticity's n-gon output becomes worse and worse with large amounts of wonky lines.
The difference is that in MOI's n-gon output, every single poly edge in the entire output is either along a trim boundary edge, or running along a surface's UV directions. There is literally not even a single polygon edge that doesn't belong to one of those categories. That makes the MOI n-gon output highly structured with a wireframe that is strongly aligned with the original CAD model.
The Plasticity generated mesh does not have that same structure to it, it will often generate edges that seem to be from an initial triangular tessellation.
MOI does not make an initial triangular tessellation, it makes an initial UV quad mesh and then with trim edges the quads are trimmed directly into n-gons. The only triangulation in MOI happens at the end if you want triangles where the n-gons get triangulated. This native n-gon meshing process is unique to MOI and not available in any commercial geometry library.
Some examples in MOI:
And same in Plasticity:
Re: N-gon meshing - especially if there are a lot of holes in large surfaces you'll see a lot of triangulated looking lines in Plasticity's fake n-gon output.
MoI result:
Plasticity result:
11865.74 In reply to 11865.73
I remember this discussion went back 12+ years ago where you talked about working on just your viewport mesher for something like 4 or 5 years before you even started to put MoI together…
You mean you didnt just download openscenegraph and buy a couple components to copy and paste from?
EDITED: 26 Dec 2025 by BURRMAN
Another one.
Message 11865.76 deleted 28 Dec 2025 by MKDM
Message 11865.77 deleted 28 Dec 2025 by MKDM
Hi Michael, how are you? Hope everything’s going well for you :)
I haven’t been hanging around the MoI forum for a while, so I’ve clearly missed quite a few things. But what really caught my attention was this strange thread I didn’t know about and that made me wonder a bit, the one titled “Michael’s Plasticity rants.”
First of all, just to be clear, I am not a Plasticity user.
So my question is, Michael: why a thread like that? Let me explain what I mean. Over all these years, you’ve always maintained a very clear and consistent approach on this forum, staying 100% focused on MoI and on your users.
Because of that, I’m honestly wondering what the purpose of a thread about Plasticity is, here in a space that’s dedicated to MoI. And above all, why you felt the need to speak (obviously for reasons you consider valid) so negatively about that software. I mean… in the end, why should you care about that software at all? If it’s poorly written, that’s the problem of whoever wrote it and whoever chooses to use it, right?
Maybe I’m missing something. Sorry if this sounds blunt, but ever since I saw the title of that thread, I’ve been wondering why something like this would come from such a serious professional like you. You really don’t need to speak badly about a so-called “competitor” to MoI.
Thanks, and I’ll also take the opportunity to wish you happy holidays :)
11865.79 In reply to 11865.78
A number of reasons were provided in this thread:
20 Dec.
>Plasticity is the only one that started out by blatantly plagiarizing my work.
22 Dec.
>Well it's in an area that I find particularly irritating - I don't like it when I see poorly designed UX being praised. And especially when it is being marketed as good UX.
23 Dec.
>If you're going to copy my stuff, why not do a proper job of it?
25 Dec.
>I guess I should explain that the original thing that pissed me off enough to start this thread was someone posting links to Plasticity advertising affiliate coupon codes after having been warned not to do that.
FWIW, I really wish that this thread had existed when I was first researching Plasticity --- I'd've bought MOI instead --- will finally be making that purchase once I've got PayPal funds lined up .
As far as marketing goes, I've always thought that the video which Naomi Wu did was a great start, and am saddened for many reasons that that was not followed up on --- that said, I did watch (and plan to re-watch) the YouTube series: Tom Meeks - 3D design for fun and life / Noun and Verb method --- perhaps an updated version of that could be done for v5?
Or just put out a video noting that if you find Blender difficulty to use, Plasticity will be too and to instead try MOI?
11865.80 In reply to 11865.79
@Will - yeah clearly my dislike of social media other than this forum has left a big marketing opening for copycats.
I guess I've finally figured out that I can at the very least make use of my own forum for some social media marketing.
The main function of the forum is for providing technical assistance to users. That aspect works best without arguments and flame wars, etc... so that's why it is a shock for some to see a combative attitude from me here. Usually I put a lot of effort into dampening that.
I will try to keep such things isolated into their own threads, I think that should work fine.
Thanks, - Michael
11865.81 In reply to 11865.80
Hi Michael, greetings :)
I read the reply from the user @Will to my question, which was addressed to you :) regarding the reason for the existence of the thread “Michael’s Plasticity rants.”
I would like to thank @Will for the explanation. However, since I hadn’t followed the history of that thread from the beginning, I was curious about why it existed—especially knowing that this style of communication is absolutely not in line with your very professional approach, which you have always maintained on this forum dedicated to Moi users.
I believe I now understand the reason for that thread, and I 100% agree with what @Will wrote in his reply when he said (I believe quoting one of your messages):
"I guess I should explain that the original thing that pissed me off enough to start this thread was someone posting links to Plasticity advertising affiliate coupon codes after having been warned not to do that.""
I also believe it is extremely frustrating and disrespectful when some people use the space of this forum to promote other products, especially when those products may even be direct competitors to Moi.
I’m not familiar with the software “Plasticity,” but from what I’ve read, it seems to be simply a very poor, poorly made copy of Moi :)
I don’t know if that is entirely accurate, but in any case, I can understand your irritation toward that software.
Best regards, and all the best :)
11865.82
Someone posted a while ago a modern UI for Moi...and to me it looked nice...
for existing user it does not make a difference...all I want is speed...for new user..I think its a plus.
Now..
Moi with...
Xnurbs
Polymodeling like Rhino
Materials
Someone mentioned the managing of the scripts...I think this is a good idea...sometimes I forget what I have installed and need to go thru the list...and cannot find it lol.
For instance...
Plasticity you can add your most used items to favorites
3dcoat spacebar I think it was you press it and you can set your most used commands
Nvil3d you can set your special commands on the side...
to me Nvil does it better
The way I have Moi3d setup it runs like a dream..I use it for everything lol....but do I need Rhino...not really but I do want it ..yes ...for the plug ins or certain features.
What makes Moi special is the scripts the were created for a specific user case.
Size: 20.2 KB, Downloaded: 82 times, Dimensions: 317x176px
11865.83
I have and like both Moi3d and Plasticity - and rarely use both of them. I almost always need to change things later on and that isn‘t easy for both programs - most of the time it is easier to restart from scratch than trying to change an existing design.
A 3d constraint system might be most fitting for history free direct modellers - something along the lines of what Solid Edge does in Synchronous Mode. Imho the first application that gets a proper implementation of 3d constraints done wins the competition :)
Message 11865.84 deleted 30 Dec 2025 by BURRMAN
11865.85 In reply to 11865.83
I think these two comments introduce a very worthwhile topic, probably worthy of a separate thread.
I use MoI exclusively for my mechanical designs and drawings but have long thought that some type of strategy and discipline is necessary in order to build a model that is amenable to modification. It is one thing to be able to get it to look good, but another level of challenge to be able to adjust relationships and dimensions as a project evolves lest the model quickly devolve into a muddle. MoI is so danged handy that I find myself using it for everything from simple sketches of parts to architecture & all of those endeavors benefit from being able to evolve the model to try out "what ifs" or adjust to new information. Perhaps a constraint system is part of a solution, I don't have any experience to offer. I do suspect that Michael may have some thoughts about how MoI could evolve to address this mutability aspect of 3D CAD.
A good natured challenge!
--Larry
11865.86
I hate all the Internet hype of Plasticity with the affiliated links everywhere. That's a warning sign my experience tells me.
Anyway since Nick Kallen has copied almost everything from Moi why not do the opposite and take whatever few good inventions he made and make them better and integrated in Moi if it makes sense :-).
11865.87
Seems to me like the two softs have different audiences really - one being for 'conceptual' hard surface, with a kind of endless output of non-practical non-machine ready modeling, the other being a focused design tool with the logic inherent in that. I'd ask how many are using it for typical cad applications but I know the answer already really. Some developers like to imagine they are building CAD products, like illustrators like to imagine they are sitting in front of a CNC machine, but they're not, so...Roll on Michael. Your diligence is appreciated out there for this razor sharp logical little bit of kit.
HAVING SAID THAT Plasticity just got instancing hahaha so I WILL poke you on that lolol (forgive me Lord)
// Rich
11865.88 In reply to 11865.87
Indeed, design for CNC and 3D printing is also my primary use case :)
Plasticity being based on Parasolid, the 3D kernel of NX, which is a top tier CAD/CAM for manufacturing solution with a very solid 3D constraints implementation in "synchronous direct modeling" mode could probably be extended into that direction (not sure which part of synchronous mode constraints is actually part of the 3D kernel and which part is exclusive to NX and SolidEdge). But perhaps there are some non-competition clauses in place with which Siemens ensures that 3rd party developers cannot use Parasolid to develop a 200€/seat NX competitor any time soon?
In that case 3d constraints could be an interesting direction for MoI on a path on which Plasticity might not be able to follow for contractual reasons. (This is all hypothetical and mainly based on my puzzlement why they haven't implemented this so-important feature from the beginning already when it is potentially all there in the kernel? But no clue, perhaps all that is not in the kernel and would be a major effort. Or 3d constraints are simply something they decisively decided against for whatever reason).
I just think it could be tremendously helpful and enable more people to use the programs in scenarios that are relevant to them.
11865.89 In reply to 11865.88
“””””constraints”””””
Hard pass…..
Nothing worse than “slop a component onto a sheet, then go back and jump through hoops to enter a bunch of engineering data…”
MoI has the ACIS modeling Kernel. Superior fillets…
NX is more of a PLM product. Lets hope Michael doesnt try to implement PLM.
""""""""""But perhaps there are some non-competition clauses in place with which Siemens ensures that 3rd party developers cannot use Parasolid to develop a 200 seat NX competitor any time soon?"""""""""""""""""""""
Sure. That's called "millions of dollars of investment and countless man hours of time developing their product". Hence, NX can create a circle and fillet a box without crashing.
EDITED: 5 Jan by BURRMAN
11865.90 In reply to 11865.89
You don't need to change constraints. Unless you want certain dimensions of the part to change. In which case you will be very glad that those constraints exist.
NX is CAD+CAM, TeamCenter is PLM.
11865.91 In reply to 11865.90
"""""""""""""Unless you want certain dimensions of the part to change. In which case you will be very glad that those constraints exist.""""""""""""""
My design abilities and artistry just shriveled up into a black, dead ball of tar on the end of my pencil....
Hard Pass.
I'll pass my models to the engineer who is well schooled in NX.
Show messages:  1-11  12-31  32-51  52-71  72-91  92-99
