Michael's Plasticity rants
 1-6  7-26  27-46  47-66  …  87-99
11865.7 In reply to 11865.2
“”””” Oh my god I've been holding in some of this for so long it seems.”””””
Hey Michael,
Next time you guys are in town, you are welcome to look me up. I can show you some neat places off the beaten path…. (If J likes salon pampering we got that covered too)
My gift to you….
Burr
11865.8 In reply to 11865.7
Thanks Burr!
So what about drawing a circle, that should be hard to mess up, right? .... right ?
I’m like ok I want to draw a circle of radius 5.
So I put down the XY point and I think ok if I type 5 and push Enter it should do it, right?
NOPE, typing 5 does nothing and (in recent builds) the Enter finishes the circle at whatever random radius your mouse happened to be at.
After messing around a bit I managed to figure out to push Tab first.
So I think OK, I just learned that I should push Tab to do numeric inputs. I don’t really like it, I mean I’d rather just type 5 with no Tab but maybe it works in a bigger context with other tools involved.
So I draw a new circle and I want to input XY numeric coordinates for the center point this time so I push Tab.
NOPE, nothing happens with Tab there, as far as I can tell there is not any way to give the x,y center coordinates.
So I think, what about commands with a distance or radius value, they must use Tab to go to that field, right?
NOPE, run the Extrude command and type Tab, nothing happens, type 5 – it switches on all pick modes up here:
Type Enter and it exits the command.
EDITED: 17 Dec 2025 by MICHAEL GIBSON
11865.10
Plasticity has some nice features....but drawing in 2d is not one of them.
It is faster for me to draw 2d in Moi and import in plasticity lol. when I work in there I feel lost :/
the other problem is its discord channel which to me is chaotic.
EDITED: 17 Dec 2025 by MATADEM
11865.11
Hello,
UX on Plasticity is rough. The most important metric in UX is time saved, no way around it. MoI takes the crown in usability in time saved. Lack of consistent expected behavior in Plasticity creates a wall of inefficiency for the user that will limit speed, it's just how the average human brain works.
People sadly form impressions over 30 second end result snippets or modeling sped up 10X. Real time process is a different story.
That said, like I bought Rhino (another example of rough UX) for the plugins (VSR, etc.), I bought Plasticity for the kernel and to a lesser extent xNurbs. I don't know of another application that has that for anything close to $300. For now there is functionality in Plasticity that doesn't exist in MoI. Copy/Paste functionality between MoI and Plasticity would be nice, adding Parasolid(?), more forgiving filleting, fine curve and surface creation and control extends MoIs lead.
Message 11865.12 deleted 18 Dec 2025 by -RB-
11865.13
Make no mistake - we ain't here for Plasticity, ain't no way ain't no how...
// Rich
11865.14
Remind me to stay away from that piece of junk - I'll stick with my MoI.
Heroes are remembered, but Spartans never die. | Proud to be a Halo fan
Taught by Tom Meeks. Small world, eh?
I'm trying to chamfer 2 edges on a cube in Plasticity and I can't figure out what I'm doing wrong.
I'm holding down shift when selecting the 2nd edge. With the 2 edges selected Fillet works ok but I get an error when trying to chamfer.
Geometry is just a boolean between 2 cubes created in Plasticity. ... ?
Work sfor me
but i have not taken same edges! :) So i must verify!
Same as you so I take 3 edges make the chamfer
then Delete vertical face
Not sure that will be the result wished! :)
11865.18 In reply to 11865.17
Thanks Pilou, I'm just trying to understand why it isn't working on those 2 edges.
Like have I made a mistake in constructing the object, is it at some improper scale, is there some option for how the chamfers come together that should be set, or whether it's not supported or a bug.
Why does the fillet work ok on it but not chamfer?
11865.19 In reply to 11865.17
Similar thing with these 4 edges selected:
11865.20 In reply to 11865.17
Works in MOI 1.0 :
It's just one cube booleaned from another cube:
Have I poked the wrong button in boolean or messed it up somehow?
Can someone build it from scratch does it do the same thing?
Some other real head scratchers
How do you make a cube freehand ? I mean just by drawing with the mouse instead of typing in sizes. I can get the bottom to be square but how do you get the height to be the same?
When picking the height of a box I can't seem to do any view navigation, what's up with that?
Are these things real or am I totally missing something?
11865.23
I see there's a full-on diss battle going on here. Honestly, I don't get why you've personally jumped into this criticism. Plasticity might appeal to some people and not to others, just like Moi3D. I own both programs, along with Blender and a bunch of other 2D and 3D CAD software. Every app has its strengths and weaknesses, but there's no denying that Plasticity is an extremely powerful tool, and for someone like me who's used to Blender, the switch is pretty straightforward, they're just different philosophies and approaches.
Plasticity has made huge strides in a short time, and even the early versions could produce great models. It's only been around for 3 years, which makes it really young, even though it uses one of the most established geometric kernels out there. Plasticity already has a ton of features that people have been begging for in Moi3D for ages, especially when it comes to NURBS surface continuity, plus a proper advanced viewport.
I use both programs together in a complementary way: I do certain things in one and other things in the other, same as with Blender.
This field is growing fast and there are plenty of competitors out there.
11865.24 In reply to 11865.23
Hi pafurijaz,
I've just had enough of exaggerations and propaganda that Plasticity invented the concept of "CAD for artists".
That's just absolute nonsense.
I receive a lot of emails from people who have tried Plasticity and are confused why they found it difficult to use after seeing a lot of hype in YouTube comments that "it's pioneered a new category of CAD for artists" or they saw on the web site that "It's the easiest to use and has the best UX", etc etc etc but nobody seems to care about actual UX, the focus is all on having the coolest looking "modern UI" and trendy icons.
It's not just Plasticity that has this focus, Apple has pushed far in that direction recently as well.
I find it distasteful when I see poorly designed UX being praised.
For an already established Blender user, Plasticity is indeed a great UX fit and I have no issue with that.
What it is not is "easiest to use" and "best UX", and it is definitely not the originator of the "CAD for Artists" concept.
For whatever reason, probably due to my own extreme intolerance of marketing, there is little information out there for me to send to someone who contacts me and asks me for my recommendation and opinions so this thread will serve for that.
If I write something that is factually incorrect (for example if there is a way to enter the x,y coordinates of a circle's origin point) please feel free to post a correction.
11865.25 In reply to 11865.24
“”””””” For an already established Blender user, Plasticity is indeed a great UX fit and I have no issue with that.””””
What a chuckle to start the day!!! :o
11865.26 In reply to 11865.24
The whole "CAD for artists" thing could just be marketing hype or a branding strategy, everyone makes their own business choices. That doesn't automatically make it untrue, though. The idea behind a "CAD for artists" is that, unlike traditional CAD software, it uses a direct modeling approach. I don't think the Plasticity developer ever claimed to have invented the concept of CAD for artists; he just said that's the direction he's aiming for according to his roadmap.
If the issue is that people keep emailing you to complain about another program, maybe you should just redirect their complaints to the right place and avoid taking on the stress of replying to folks dumping their grievances on you. After all, FreeCAD and Blender are complicated too, and don't get me started on gCAD3D, it has a terrible UI as well.
The fact that you're especially annoyed by Plasticity, but not by the hundreds of other apps out there, makes me think you might see it as a potential competitor. Otherwise, you'd be making long threads about tons of other programs too.
I'm not saying your points about certain flaws are wrong, but focusing on a few minor issues while ignoring everything else that's good about it feels like a gratuitous attack.
There are plenty of programs that people around here don't like, Blender and FreeCAD especially, but that doesn't mean they're bad applications.
I hope in the future the competition focuses on the features offered, rather than pointing out the flaws in everyone else's software.
Greetings.
Show messages:  1-6  7-26  27-46  47-66  67-86  87-99
