Solid in 2 parts !
All  1-3  4-12
11857.4 In reply to 11857.3
Hi Zooen, that's called a "disjoint brep". Most commands where that could occur do some work to separate those into individual objects. You can do that to fix it by using Edit > Separate followed by Edit > Join.
To fix what happened in your particular case here I would need to repeat the steps that created it instead of only seeing the end result.
Do you remember what command you were using that produced it?
11857.5 In reply to 11857.4
Bonjour Michael,
From Revit, I exported the 3D view of the completed building in .sat format. I chose this format because MoI 3D and Blender can import .sat files.
Then I looked at the window panes in the Blender file to apply a transparency property to them for rendering; and that's when I realized that the window panes were made up of two elements. Intrigued, I checked to see if the same thing happened in MoI 3D, and it turned out that it did, as you can see. That's it, nothing else.
For your information, many 3D building construction elements are created by manufacturers in DWG, DXF, RVT, etc. formats for use by architects, engineers, and building design office technicians. This is the case, among others, for the windows and French windows that I used.
It intrigues me, but it doesn't hinder my project.
EDITED: 12 Dec 2025 by ZOOEN
11857.6 In reply to 11857.5
Probably have to do a bit of work in Revit first
Being a BIM modeler and app, things like these windows are setup as “Families” and various other elements that interact in IFC and shares with autocad and large scale projects.
Look at converting families to parts. Exporting the parts you want out. You woulnt want to start with exporting your “building” to look for good single working models all perfectly individualized components and parts. Probably run into lots of issues with stuff
11857.7 In reply to 11857.5
Hi Zooen, can you post the .sat file here or e-mail it to me at moi@moi3d.com?
But if Revit has created a single brep made up of disjoint faces, then MoI is just reading in what Revit has generated.
Since I'm not developing Revit I don't know why they would want that, you could ask them I guess?
What happens if you load the SAT back into Revit, is it separated there?
If you can send me the file I can see how some other programs interpret it.
11857.8 In reply to 11857.7
For those following this post, I sent Michael the .sat file for one of the windows in the project, as well as the .rfa file created by the window manufacturer selected for the project.
Michael@ "But if Revit has created a single brep made up of disjoint faces, then MoI is just reading in what Revit has generated". Yes, I agree, that makes sense to me. But these are not disjoint FACES, it is a "double solid" of sorts.
If anyone knows how to make a "double solid" in MoI3D like the one I posted above, please explain to me how to do it. And I think Santa Claus will give him the gift of his dreams!
11857.9 In reply to 11857.8
Hi Zooen,
In most places where that could occur it gets broken up into separate objects.
But one way to do it currently is with the new move face, if you move a face far enough that it divides the solid into 2 pieces you will get a brep object with a disjoint shell:
Sometime soon I'll be fixing it up to separate those into 2 separate solids.
Yes actually it's called a "disjoint shell". In CAD topology there is usually a topological container called a "shell" that has a list of faces in it. There isn't anything about the topology's structure that ensures that all faces are connected to each other.
11857.10 In reply to 11857.9
Thank you for this information.
I have not yet fully integrated these latest developments into my daily practice.
I think "le père Noël" will grant your wishes for Christmas! (Note: corrected on Larry's advice, read the following posts below)
EDITED: 14 Dec 2025 by ZOOEN
11857.11 In reply to 11857.10
> I think Santa Claus will grant your wishes for next Christmas!
Aw, Zooen, I think he deserves to have his wishes granted THIS Christmas!! ;-}
And to the topic/question you raised, I think Michael's answer is both surprising and quite interesting. I really appreciate these little tidbits explaining the "why" of how things work!
--Larry
11857.12 In reply to 11857.11
Hi Larry,
Larry@ Aw, Zooen, I think he deserves to have his wishes granted THIS Christmas!!
Of course you're right. I'm on the old continent, and in my mind I was thinking of Father Christmas (translation error). Right, I'll quickly correct that (he's still asleep, le père Noël he's an old man, like me!!).
Larry@ And to the topic/question you raised, I think Michael's answer is both surprising and quite interesting.
I agree with you on that point. And above all, we must always remain curious.
Show messages: All  1-3  4-12
