RE_HIDE_HIDDEN
11855.1
hi Michael,
is there a script that can act as the eye button on the hidden layer ?
just want to quickly re hide all the stuff i dump in hidden layer .....wish this layer would not show up when un hide command runs and to un hide HIDDEN LAYER user has to click a button instead. its hidden for a reason right lol.
cheers neil
11855.2 In reply to 11855.1
Hi neil,
I'm not sure what you mean by "the hidden layer" - do you mean a style that is named "Hidden"?
11855.3 In reply to 11855.2
yes the style called hidden
11855.4 In reply to 11855.3
Hi neil, paste this in as the "command" part of a shortcut key. Then when you press that key all objects assigned to a style named "Hidden" will be hidden.
script: var objects = moi.geometryDatabase.getObjects();
var style = moi.geometryDatabase.findStyle( 'Hidden' );
if ( style )
	for ( var i = 0; i < objects.length; ++i )
		var obj = objects.item(i);
		if ( obj.styleIndex == style.index )
			obj.hidden = true;
		var subobjs = obj.getSubObjects();
		for ( var j = 0; j < subobjs.length; ++j )
			var subobj = subobjs.item(j);
			if ( subobj.styleIndex == style.index )
				subobj.hidden = true;
11855.5 In reply to 11855.4
thank you i wanted that one. legend
