Twisted Candy Cane
All  1-5  6-20
11845.6 In reply to 11845.5
After watching the video, I just had to try it in Moi.
Didn't think about Flow to deform. I tried to do it with twist alone, twist didn't do the curved part right...
Is twist only for straight parts/objects?
Thanks to both of you, this looks like the way to do it.
Thanks again! Much appreciated!
Can't say enough about the forum here and its members as well as MOI.
Just love it!
11845.7
In practice, I would prob create the pattern using uv's (by simply offset the coordinate in your DCC/render software).
But if you want to build it as geometry, you can also use the flow deform, that can act like a uv conform operation.
You need the pattern, as source surface (a simple plane), and a sweep tube (with no cap).
It's better to resample the curve use for the sweep to create evenly point distribution (rebuild command).
Actually the hardest part is to find the right position on the surface when building the flow deform.
You have to pick the pattern, the source plane, then the target sweep surface, but depending where you click, the pattern orientation can be tiled, it's not always easy to find the right spot.
(I wish we could change the direction in the flow option instead to redo the 3 steps operation over and over)
We want to eat that! :)
My Moi French Site
11845.9
A while ago, I added the "SwapUV", "FlipU", "FlipV" and "Update History" options to the flow command's UI for the same reason. They were documented for the scripting but not used in the UI, I guess for ui simplicity.
I'll attach it here
11845.10
Ho now that's super neat, I new the few hidden commands, but I didn't know some parameter where also hidden in the interface. Thanks a lot for sharing this !
Flow command was yet some powerful, now it's a monster of power! ;)
My Moi French Site
11845.12
A nice way to model the part.
Another thumbs up for the extra functions in Flow.
Thanks to both of you.
Martin.
11845.13 In reply to 11845.9
@ Mo
In what folder must be placed this extra Flow Options ? In commands ?
In fact Both Normal folder Moi /commands Roaming folder / Moi / Commands
EDITED: 29 Nov 2025 by PILOU
11845.14 In reply to 11845.13
I've replaced it with the original "Flow" command, but if you want to keep the original, you can rename it to something else (for example, "Flow2.htm" and "Flow2.js"), place it in the "moi appdata commands" folder, and assign a shortcut (for example, Shift+F=Flow2). This way you don't need to replace it with every new release.
11845.15 In reply to 11845.14
My Moi French Site
11845.16 In reply to 11845.7
Super cool! Also thanks to MO for the updated Flow!
11845.17
I'm seeing the Update History but not the Swap and Flip UV commands. Are these commands available somewhere? Thanks for sharing this Mo!
11845.18 In reply to 11845.17
Hi danperk, those other options are only applicable for surface-to-surface Flow.
In your screenshot it looks like you're doing a curve-to-curve Flow instead.
11845.19
Ah Thanks Michael, got side tracked by a candy cane! This is great, I've lost track how many times I've manually updated History for this kind of stuff.
11845.20
"ExtraFlowOptions.zip" Thanks Mo for this! Flow is indispensable to us Jewelry Designers! :)
Show messages: All  1-5  6-20
