Array curves between curves or 3d shape?
All  1  2-3
Seems CMorph is for you ?
https://moi3d.com/forum/index.php?webtag=MOI&msg=6373.1
And / Or Line web if you want some more curve on it!
https://moiscript.weebly.com/lineweb.html
Of course top can be planar closed if needing! :)
Here CMorph + LineWeb
EDITED: 20 Nov 2025 by PILOU
11839.3 In reply to 11839.1
Hi Matadem, you can find the cmorph plugin here:
http://moi3d.com/wiki/MaxScriptArchive
or for your curves case you may want to use Construct > Loft to build a solid between the shapes and then you can extract section lines from a solid or surface either by arraying a line and using Construct > Curve > Project or by arraying planes and using Construct > Curve > Intersect.
Here using Transform > Array > Dir on a line and then Construct > Curve > Project:
Show messages: All  1  2-3
