Array curves between curves or 3d shape?
11839.1
Hello
if I have 2 curves ..the top and the bottom are 2 different sizes...how would I array the shapes between them? even if they are not centered.
and if I have the same situation but in 3d ...so if I have boolean the shape out of a block/rectangle...how would I get the curves between them...?
Tnx!
Size: 163.9 KB, Downloaded: 66 times, Dimensions: 1270x401px
Size: 48.2 KB, Downloaded: 58 times, Dimensions: 895x532px
Seems CMorph is for you ?
https://moi3d.com/forum/index.php?webtag=MOI&msg=6373.1
And / Or Line web if you want some more curve on it!
https://moiscript.weebly.com/lineweb.html
Of course top can be planar closed if needing! :)
Here CMorph + LineWeb
EDITED: 20 Nov 2025 by PILOU
11839.3 In reply to 11839.1
Hi Matadem, you can find the cmorph plugin here:
http://moi3d.com/wiki/MaxScriptArchive
or for your curves case you may want to use Construct > Loft to build a solid between the shapes and then you can extract section lines from a solid or surface either by arraying a line and using Construct > Curve > Project or by arraying planes and using Construct > Curve > Intersect.
Here using Transform > Array > Dir on a line and then Construct > Curve > Project:
