display hidden lines is not working
All  1-7  8-11
11834.8 In reply to 11834.7
Hi Wim,
> the one UI mod I did was the one you showed me a few years ago, to have all the
> interface windows open at the same time.
It's probably from this script.
What happens if you disable the script, does your "Display hidden lines" checkbox work ok then?
You can disable the script by temporarily moving it out from the MoI appdata startup folder or renaming it to something other than having a .js file extension, like .jsx .
11834.9
Yes Michael, that is the one, renaming did not help, removing the .js did.
wim
11834.10 In reply to 11834.9
Thanks Wim, I'll see about fixing the script.
11834.11 In reply to 11834.9
Hi Wim, please try this attached updated version of the script. Should work on v4 or v5.
If this fixes the broken "Display hidden lines" checkbox I'll also update the one on the original post.
Thanks, - Michael
Show messages: All  1-7  8-11
