Pick base point
All  1  2-5
11830.2 In reply to 11830.1
Hi Marek, do you mean in the Draw Solid > Text command?
It's normal for there to be some space between the edge of a character's cell and the character's geometry.
The specific amount is different for every font and is part of the font's design.
It would be pretty unusual to try and override the font's intended spacing.
So if you need to position it differently that's something you would need to do after it's been generated.
11830.3 In reply to 11830.2
Yes, that Text command.
So, the Pick base point relates to spacing for each font?
Well, then after getting several Text objects to have them aligned to say to the vertical red line which I put at the location of the guideline I have to move each object by hand, right?
Size: 111.9 KB, Downloaded: 52 times, Dimensions: 507x1114px
Size: 175.7 KB, Downloaded: 56 times, Dimensions: 663x1365px
11830.4 In reply to 11830.3
Hi Marek,
The base point is where the bottom left point of the first character's cell will be placed.
No, the Transform > Align command can help with that.
Select each line of text and put it in a group (Scene Browser > Objects > "..." menu) so it will move as one unit.
Select them all:
Run Transform > Align and choose the "Left" option:
Pick the point on your line:
Does that give you the positioning you want?
11830.5 In reply to 11830.4
Sure it does, thank you.
Case closed.
Marek
Show messages: All  1  2-5
