Thumnail Preview Image
11829.1
I activated the extension in my Mac Studio Tahoe 26.1
Also, I checked the option in MoI3D V5 Beta SEP-17-2025
but i haven't thumbnail on MoI files, just MoI icon. Is it normal?
See my screenshot.
Size: 85.3 KB, Downloaded: 30 times, Dimensions: 640x208px
11829.2 In reply to 11829.1
Have you opened and saved your files after checking the option ?
Have fun !
11829.3 In reply to 11829.1
Hi Finema, I updated to Tahoe 26.1 to test it and the thumbnails are working ok for me over here.
Could you post an example .3dm file that is not getting the thumbnail so I can verify that it has the thumbnail image in it?
Also the system setting UI for enabling the extensions is kind of confusing.
Under System Settings, it's under General > "Login Items & Extensions" and then to enable it you need to click the circle with an "i" in it which doesn't really look like a clickable thing. Then it will show the enable/disable switch.
So please double check that it is enabled.
11829.4 In reply to 11829.3
Here a file (just a sphere). This file not getting the thumbnail.
In System Settings, the extension is enabled.
Reboot my mac, but no result.
11829.5 In reply to 11829.4
Hi Finema, your file looks fine. It has a thumbnail stored in it and over here it is being displayed when the file is on the desktop:
Where is the .3dm file located on your system, is it on the desktop or somewhere else?
What is the full path to it?
Also if you have it on the desktop and select it and push space what does the preview window show for "open with", does it possibly have an old version listed in there? :
Man these cartoonishly large rounded corners all over in Tahoe are gross.
EDITED: 10 Nov 2025 by MICHAEL GIBSON
11829.6 In reply to 11829.5
Thanks Michael
Everything is ok though…
See my screenshots
For info, in the .ini file, i have :
[3DM]
Version=
WriteThumbnailPreviewImage=y
ThumbnailSize=256
It's OK ?
EDITED: 10 Nov 2025 by FINEMA
Size: 229.7 KB, Downloaded: 42 times, Dimensions: 1218x664px
Size: 37.8 KB, Downloaded: 34 times, Dimensions: 890x156px
11829.7 In reply to 11829.6
Hi Finema,
> [3DM]
> Version=
> ThumbnailSize=256
>It's OK ?
Yes, those settings are ok. They are the default values.
11829.8 In reply to 11829.6
Hi Finema, something else to check -
Click on your desktop and then on the Top menu click View > "Show view options"
Then make sure "show icon preview" is on.
11829.9 In reply to 11829.6
And another thing you can try is from a Terminal prompt put in:
qlmanage -r cache
That will reset the thumbnail cache, it could help if it got damaged somehow.
11829.10 In reply to 11829.9
Idem, no thumnail
11829.11 In reply to 11829.10
Hi Finema, is the v5 beta also listed as being given permissions to access files?
I think that's under System Settings > Privacy & Security > "Files & Folders".
11829.12 In reply to 11829.11
I checked the permissions in the system settings.
I also completely uninstalled Moi3D and reinstalled but still no preview.
Thank you.
