Script to automatically export and save stl file
All  1-3  4-7
11823.4 In reply to 11823.3
Hi Matadem, also when you export to an .stl file normally the "Meshing options" dialog box is shown so you can adjust the mesh density.
Do you want that dialog to be shown or do you want it to use some some specific mesh settings each time and if so what settings?
11823.5
Attached is what I use.
I does not even need to pop up since I do not change anything...
Thanks!
Size: 20.2 KB, Downloaded: 52 times, Dimensions: 284x265px
11823.6 In reply to 11823.5
Hi Matadem, try this script you can put it in as the "Command" part of a shortcut key:
script: var dir = 'c:\\scripts\\'; var filename; var counter = 0; while ( 1 ) { ++counter; filename = dir + 'stl' + counter + '.stl'; if ( !moi.filesystem.fileExists( filename ) ) { break; } } moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3.0' );
Change the 'c:\\scripts\\' to your output directory, backslashes need to be doubled and there should be a backslash at the end.
It will write an .stl file named stl1.stl, stl2.stl, etc... , bumping up the number until it finds an unused one.
11823.7
Nice Thank you! work great.
Show messages: All  1-3  4-7
