Helix rounded on average possible
All  1  2-8
Here i take a diagonal of a rectangle
Then Flow it on any symmetric bowl ( because curriously project a curve don't works)
I had one turn!
So stack the bowls !
That must make the trick! ;)
11814.3 In reply to 11814.1
Select curve and use the twist tool.
Barry
11814.4 In reply to 11814.2
Thx. But I cannot follow your workflow.
11814.5 In reply to 11814.1
see photo.
Barry
About my not speed method :)
Sorry in fact you don't stack the bowls but you trim it horizontally!
Then Flow the diagonal of the rectangle on each slice bowl part :)
Not the helix following!
EDITED: 16 Oct 2025 by PILOU
11814.7 In reply to 11814.1
Hi Mala, if you're still stuck you can also reference this previous discussion thread here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11777.1
11814.8 In reply to 11814.7
Almost perfect for my effort, Michael. Thank you very much!
Also to all your other ideas !
Best, Mala
Show messages: All  1  2-8
