Sweep fails - why?
All
1-15
16-20
Michael Gibson
16 Oct 2025 (16 of 20)
11813.16
In reply to
11813.7
Hi Mala, also the same steps will also work for your sweep fail 3.3dm file above.
result attached.
sweep fail 3 fixed.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
16 Oct 2025 (17 of 20)
11813.17
Maybe more simple...
And advantage you can have start and target section different... here 2 circles but...
Make a boolean Diff between cylinder and plane
EDITED: 16 Oct 2025 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Lara (MALA)
16 Oct 2025 (18 of 20)
11813.18
Ok. I learned very much (again). Thanks to you Michael and also for the smart way, Pilou!!! Now I can progress...fine.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Barry-H
16 Oct 2025 (19 of 20)
11813.19
In reply to
11813.18
attached photo shows a method to get the twist direction you require. By creating a surface with desired twist.
Then array required section along curve aligned to surface and finally loft sections.
Barry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Lara (MALA)
16 Oct 2025 (20 of 20)
11813.20
In reply to
11813.19
Thank you!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-15
16-20
