A script to select name (profile) Network them then planar the surface
11806.1
Hi Michael
I have 26 signet rings to make and is it possible to automate the following into a script line on 1 key
Moi ver 4
select all curves called "prof" 6 curves
Network them into surface
then Planar the resulting surface to make a solid
then boolean difference the curve called "size"
Many Thanks
shayne
11806.2 In reply to 11806.1
Hi Shayne, here you go.
Instructions for installing a plugin here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
for test...
My Moi French Site
11806.4
Thanks so much Michael
that is fantastic
Kind regards
shayne
