Forgotten nodes in Elephant
All  1-3  4-6
Perfect ! And I have that in French! :)
Does the 07.02 is the last version ?
Why only "X" on the node "Pts2pts" ? (and not also "Y" & "Z" as it's 3D points in the space)
My Moi French Site
When i draw my own points seems each point draw a line to the other points!
I want of course only a line!
I must make something special first ?
When i load the previous file that works normaly... apparently... when you select them... but
i suspect the same process : each point connects all the other ones on the same line! ;)
It's for that my lines was "fat lines" on my previous image! :)
So I suppose than the node must be modified!
A vicious glitch is hiden somewhere! :)
EDITED: 25 Sep 2025 by PILOU
Effectively with your file in selecting only "one fat line"! ;)
Must be maybe 9 points , (n points-1) lines ... or better one line!
I believe that is a nightmare to choise a cluster of points but it will be yet nice for one selection of points for an line alone!
will be yet a good start! :)
EDITED: 26 Sep 2025 by PILOU
Show messages: All  1-3  4-6
