V5 beta Sep-17-2025 available now
 1-6  7-26  27-46  47-66  …  87-104
11803.7 In reply to 11803.6
Great improvements! Thanks, these updates are pretty useful.
11803.8 In reply to 11803.6
Hi Mip,
> In the "remove fillets" video, you seem to remove the fillets by selecting adjacent faces.
I used a "Invert selection" shortcut key to switch selection onto the fillets after selecting the larger faces.
Sometimes it is easier to select the pieces you want to keep and then invert.
If you want to set up a keyboard shortcut for invert selection, put this on a shortcut key:
script: moi.geometryDatabase.invertSelection();
(EDIT: looks like you figured that out already)
> Also, it is interesting to note that moving a face(s) over holes will "erase" them.
> When extending the face again, we have a clean surface.
> It can be a fast way to delete many holes at once.
Yes, it will be interesting to see how it behaves when pieces bunch up.
Another thing that I want to set up for a circular hole to be able to change its radius.
11803.9
Question will be scaling of the holes be possible? same as moving them around?
Tnx!
Remark that the "Remove Fillets" Remove also "Chamfers" ! ;)
My Moi French Site
11803.11 In reply to 11803.9
Hi Matadem,
Yes I think I will be able to do that. Probably if cylindrical faces or circular edges are selected then
the current radius or diameter will be shown here and then click on that to change it:
There is actually a display and edit menu there since version 2 I think but it scales the entire object instead of modifying just the hole.
And what about Move Copy, Rotate Copy ?
My Moi French Site
11803.13 In reply to 11803.12
It looks like there's a bug with Rotate copy, it was intended to retain the previous version behavior there. I'll see about fixing that.
11803.14
Looking good Michael, thanks for all your work on this.
3D Hard Surface
mbt3d.com Artstation
11803.15
Impressive!!!!
Works fine...
My Moi French Site
11803.17 In reply to 11803.16
Wow cool features :)
Thanks Mickael
11803.18
Wow, this opens up whole new ways for constructing objects !
I’m looking to explore and integrate these features.
I appreciate your patience and dedication to bringing your vision to life.
Moi's focused interface is truly impressive.
Marc
11803.19 In reply to 11803.1
OMG
MoI became magical...
Thank you Michael!
I wanted to test moving holes on curved surfaces. It seems to work when cutting the hole in formed solids.
If I create a curved surface, "trim the hole" then shell for thickness, the Move produces an artifact in the hole (For me. Lets see if its reproducible)....
Here is a file
11803.21 In reply to 11803.20
Hi Burr, thanks for the test file. I've had a few cases sent in where closed surfaces in particular are getting mangled similar to what you have here. That is next up for me to work on tuning up.
If you cut the hole after shelling instead of before it, that seems to work better right now (see attached file).
11803.22 In reply to 11803.21
Yes Michael, so far for me it surfaced only when “creating the solid” AFTER the hole trim in the surface…
Noted
One possible thing i noticed but it could be erroneous was picking a point “in the bottom of the hole” to do the move
So normally picking a point at the top surface, but if the point was picked down through the hole at the bottom edge of it… just something to look for. It may not be anything.
Thanks again.
A black hole! :)
My Moi French Site
11803.24 In reply to 11803.21
The corrected file and creation process has the "Move" actually perform faster and smoother also... not just "mangled surface"
Just a note from a fading laptop...
11803.25 In reply to 11803.24
Question regarding the fillet options. The ACIS fillet loses the ability to use the G2 and G3 options. Do you plan on keeping the Solids++ or can ACIS produce these options in the future?
Thanks.
11803.26
Thanks for the new beta Michael!
Show messages:  1-6  7-26  27-46  47-66  67-86  87-104
