V5 beta Sep-17-2025 available now
 1-19  20-39  40-59  60-79  80-99  100-104
11803.60
Fabulous woohoo
11803.61
Fantastic update!
11803.62 In reply to 11803.61
How to add code in MOI3D to run batch files (.bat) in WIN10?
11803.63 In reply to 11803.62
Hi feirui445,
You can set up a shortcut key that will launch a batch file when the key is pressed, is that what you want?
Put this as the "Command" part of the shortcut key (note use additional backslash \ because that is the escape character in javascript):
script: moi.filesystem.shellExecute( 'c:\\scripts\\test.bat' );
11803.64 In reply to 11803.1
Thanks a lot Michael!
11803.65
So, faces can be manipulated... can edges be manipulated as well, or is it faces only?
Heroes are remembered, but Spartans never die. | Proud to be a Halo fan
Taught by Tom Meeks. Small world, eh?
11803.66 In reply to 11803.65
Hi SPARTAN-D421,
Faces only.
11803.67 In reply to 11803.66
Gotcha. Thanks.
11803.68
i tried to install the new beta on my MacBook pro (Core i9, 2015) with Sonoma (14.7.2). But when i run the terminal and type in the password: No success.
Only a password character appears, but no cursor. I have no way of entering a password. I tried entering my password, and I tried copying and pasting it. But nothing worked. Does anyone know what's going on?
Oh man, I'm such an idiot! I entered my MOI license code instead of my device password. Now it works. Sorry for my unnecessary post.
Best regards
Wolfgang
EDITED: 17 Nov 2025 by WSIEW
Size: 80.3 KB, Downloaded: 129 times, Dimensions: 592x378px
11803.69 In reply to 11803.68
Don't worry. These things happen.
Happened to me the first few times I used Linux, actually.
11803.70
With this new beta, when I right click to orbit (about half the time) it opens up a file open dialog when I release the right mouse button. Any ideas?
>Len
11803.71 In reply to 11803.70
Hi Len,
Are you doing a right click to orbit but then releasing the button without any movement?
When you right click in a viewport like that it's a shortcut for pushing the "Done" button or if you are not currently in a command it will repeat the last used command. If you have just opened a file then the last used command is Open.
If you don't want the Open command to repeat like that there is a setting in moi.ini you can use. Go to Options > General > "Edit .ini file" button and in the [Commands] section there is a setting NonRepeatingCommands, add open to it so it looks like this:
NonRepeatingCommands=delete undo redo open
11803.72
Oh yeah, the right-click repeat trick. My personal favorite.
11803.73
Hi Michael, what you think to add ability make differen color to construction lines? For concepting, make them separate by angle visially
11803.74 In reply to 11803.73
Hi blackboard,
Do you mean by assigning a style? Or by some automatic process?
11803.75 In reply to 11803.74
Thanks for fast answer Michael.
For my problem - to find visualy similar angles of surfaces i think will be better to have automatic ability made it different color when this lines on custom angle not 0\90\180\270\360.
I propose when in scene you have two or more same angle constraints - bind them a one special color. If someone add them on one angle and with custom angle i think this have sense to visualy made it clearer(For some reason user made it a couple versions and i think it can improve user expirience). When this construction lines more it can be a mess.
I think also add checker box to change it from gray to multicolor made sense too, or make also not vivid colors
Size: 35.9 KB, Downloaded: 130 times, Dimensions: 1028x708px
11803.76 In reply to 11803.75
Hi blackboard, it's an interesting idea but that's a lot of things to try and control. It seems like it would be a pretty complex UI.
11803.77
Love the update! I've had a blast modelling some simple lens holders today and couldn't resist playing with the new features.
The move face feature covers one of my main pain points when switching to MoI from Rhino (would love to see ability to move edges). Heck, at this point the only annoying thing that immediately comes to my mind when I think of it, is selection priority when making fillets / chamfers. If I extrude a profile and then want add some fillets to the edges of a resulting solid the original curve overlaps with the edges - and comes in the way. Fillet command picks this curve instead of edge. Would love to have some sort of selection priority with this command - pick edges first, if none pick curve.
In Rhino this is not that annoying as Rhino asks which object you wish to select when there are overlaps (so in this case - a menu would appear with option to pick edge or curve). It's not fantastic either, but definitely less annoying.
For the time being I've mapped a key to hide curves... but that's not really great solution.
But that sounds a bit like a rant - which it really shouldn't. The update is fantastic. And a side note - I'm surprised how well in works on my Linux box with tiling window manager (Hyprland) via Wine. One of the reasons that instead of launching a VM with pcie passthrough (and LookingGlass) or grabbing my Rhino laptop I simply did the modelling in MoI (and I'm glad I did :) ).
11803.78
Michael, so glad to see you are still at it.
It's been soooo long...the website where I first heard about moi3d (cgtalk) doesn't even exist anymore. :)
Hope you are doing well, and wish all the community here prosperity in the new year.
11803.79
If I open a .stp or .igs (may be others, those are just the ones I have), there is now way to know what file is open in the MoI widow. Is there a way to add the file name somewhere?
.3dm shows the file name in the top window bar.
Show messages:  1-19  20-39  40-59  60-79  80-99  100-104
