V5 beta Sep-17-2025 available now
 1-11  12-31  32-51  52-71  72-91  92-104
11803.52 In reply to 11803.51
Hi stefano,
> could you consider the concept of a "master hole" whereby if a hole object created
> or duplicated a user can later on change the single master hole diameter to change
> all such hole sizes..
One method that could work for this already within current capabilities would be to assign a name to the hole's face or edge object.
After the name has been set there will be an entry for it in the "Objects" section of the Scene Browser and you can go there to select all of the hole geometry with one click.
One issue that could complicate that is that when an object is contained inside of a group the name only shows up as a child of the group instead of showing at the top level. Maybe that could be solved by having an option that you could set on objects for having the name appear at the top level or inside of the parent group...
11803.53 In reply to 11803.52
hi michael yes was thinking along those lines; as i saw some holes in the above thread (already extruded and part of a solid being moved around). i iwas curious if theres some smart way to make punched out or pass through holes all change size quickly in a click or two, eg could this also work with holes in sheet metal. typical example change all 5mm pass through holes in 3mm aluminium sheet to 5.3mm. i dont relly want to have to select all the indicidual holes just select the "named object" change the radius / diameter and maybe the object type name to "hole 5.3mm" and they all change...fyi: just back from a trip and not in work mode or front of pc with your new beta installed.
11803.54
SUPER UPDATE !!! ... Majestic work, Michael !
I almost feel like a sinner for being late to see this update for about half a month!
Message 11803.55 deleted 6 Oct 2025 by FUBAX
11803.56 In reply to 11803.1
Awesome, thank you!
11803.57
Hi, the new move tool is awesome, using it all the time. Bravo!
Moujiik
11803.58
> new move tool
Wait... what?!
[le check changelog]
Oh, holy heck, that's genius!
That is totally gonna come in handy! I can finally make those on-the-fly adjustments to my coin canister project now!
Heroes are remembered, but Spartans never die. | Proud to be a Halo fan
Taught by Tom Meeks. Small world, eh?
11803.59
Yeessss!!! Thanks Michael - esp for the remove fillets!
11803.60
Fabulous woohoo
11803.61
Fantastic update!
11803.62 In reply to 11803.61
How to add code in MOI3D to run batch files (.bat) in WIN10?
11803.63 In reply to 11803.62
Hi feirui445,
You can set up a shortcut key that will launch a batch file when the key is pressed, is that what you want?
Put this as the "Command" part of the shortcut key (note use additional backslash \ because that is the escape character in javascript):
script: moi.filesystem.shellExecute( 'c:\\scripts\\test.bat' );
11803.64 In reply to 11803.1
Thanks a lot Michael!
11803.65
So, faces can be manipulated... can edges be manipulated as well, or is it faces only?
11803.66 In reply to 11803.65
Hi SPARTAN-D421,
Faces only.
11803.67 In reply to 11803.66
Gotcha. Thanks.
11803.68
i tried to install the new beta on my MacBook pro (Core i9, 2015) with Sonoma (14.7.2). But when i run the terminal and type in the password: No success.
Only a password character appears, but no cursor. I have no way of entering a password. I tried entering my password, and I tried copying and pasting it. But nothing worked. Does anyone know what's going on?
Oh man, I'm such an idiot! I entered my MOI license code instead of my device password. Now it works. Sorry for my unnecessary post.
Best regards
Wolfgang
EDITED: 17 Nov 2025 by WSIEW
Size: 80.3 KB, Downloaded: 129 times, Dimensions: 592x378px
11803.69 In reply to 11803.68
Don't worry. These things happen.
Happened to me the first few times I used Linux, actually.
11803.70
With this new beta, when I right click to orbit (about half the time) it opens up a file open dialog when I release the right mouse button. Any ideas?
>Len
11803.71 In reply to 11803.70
Hi Len,
Are you doing a right click to orbit but then releasing the button without any movement?
When you right click in a viewport like that it's a shortcut for pushing the "Done" button or if you are not currently in a command it will repeat the last used command. If you have just opened a file then the last used command is Open.
If you don't want the Open command to repeat like that there is a setting in moi.ini you can use. Go to Options > General > "Edit .ini file" button and in the [Commands] section there is a setting NonRepeatingCommands, add open to it so it looks like this:
NonRepeatingCommands=delete undo redo open
Show messages:  1-11  12-31  32-51  52-71  72-91  92-104
