V5 beta Sep-17-2025 available now
 1-3  4-23  24-43  44-63  64-83  84-103  104
11803.44 In reply to 11803.43
Michael.
I click to start the line and immediately begin typing on the numeric keypad and the numbers are displayed in the X,Y,Z box without me clicking on it.
If I click to start the line and then type: 4-7/8" the line is correct.
If I click to start the line and then type: 4 7/8" the line terminates somewhere near the Origin, in fact all lines show similar behaviour whe using the 'space' character.
Martin.
11803.45 In reply to 11803.44
Hi Martin,
> all lines show similar behaviour when using the 'space' character.
In that particular field it's also looking for x y values and it's deciding that 4 7/8" is a 2D point location with
x = 4
y = 7/8 inches = 22.225mm.
But I can probably tune that if you have the inches mark (") on just one piece then treat the whole thing it as one feet & inches value instead.
11803.46 In reply to 11803.45
Hi Michael.
That would be good if you're happy to do it.
Just to let you know that the new features are an absolute boon when it comes to editing a model. Just being able to delete features to allow further editing is fantastic!
Thanks.
Martin.
11803.47
The moi3d function is already well-developed and easy to operate. As a purchasing user, could you consider designing a new UI to enhance the competitiveness of this product,https://www.behance.net/gallery/175633629/Moi3D
Size: 37.2 KB, Downloaded: 255 times, Dimensions: 404x316px
Size: 184.3 KB, Downloaded: 221 times, Dimensions: 2275x1280px
11803.48 In reply to 11803.47
Hi feirui445,
There is a new "Dark Mode" UI available in version 5, you can turn it on under Options > General > "UI Theme: Dark".
See here for some discussion of some of the problems with that particular graphic design example that you link to:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11158.2
Just purely cosmetic graphic design "looking cool" is a very low priority for MoI compared to actual workflow UX design.
I'm definitely not interested in losing actual usability just for a cool look.
11803.49
Interesting.
11803.50 In reply to 11803.47
If MoI had looked like that when I wanted to buy a CAD, I'd have carried on looking.
Martin.
11803.51 In reply to 11803.20
hi michael liking the look of this! will download soon....just wondering as there was a bit of talk about holes...could you consider the concept of a "master hole" whereby if a hole object created or duplicated a user can later on change the single master hole diameter to change all such hole sizes...in coreldraw this is done with "clone" command but ot needs a bit too much discipline to remember always to duplicate the clone hole, nonetheless its really useful in certain instances, not really parametric but very simple and very useful; espescially as a lot of times in simple sheet metal or planar work changing fixings types often mean changing hole sizes all over again and again - with even 10 holes or 100# that can be very tedious work..im thinking the object manager "master object" could maybe be used to acheive this in a creative way?
11803.52 In reply to 11803.51
Hi stefano,
One method that could work for this already within current capabilities would be to assign a name to the hole's face or edge object.
After the name has been set there will be an entry for it in the "Objects" section of the Scene Browser and you can go there to select all of the hole geometry with one click.
One issue that could complicate that is that when an object is contained inside of a group the name only shows up as a child of the group instead of showing at the top level. Maybe that could be solved by having an option that you could set on objects for having the name appear at the top level or inside of the parent group...
11803.53 In reply to 11803.52
hi michael yes was thinking along those lines; as i saw some holes in the above thread (already extruded and part of a solid being moved around). i iwas curious if theres some smart way to make punched out or pass through holes all change size quickly in a click or two, eg could this also work with holes in sheet metal. typical example change all 5mm pass through holes in 3mm aluminium sheet to 5.3mm. i dont relly want to have to select all the indicidual holes just select the "named object" change the radius / diameter and maybe the object type name to "hole 5.3mm" and they all change...fyi: just back from a trip and not in work mode or front of pc with your new beta installed.
11803.54
SUPER UPDATE !!! ... Majestic work, Michael !
I almost feel like a sinner for being late to see this update for about half a month!
Message 11803.55 deleted 6 Oct 2025 by FUBAX
11803.56 In reply to 11803.1
Awesome, thank you!
11803.57
Hi, the new move tool is awesome, using it all the time. Bravo!
Moujiik
11803.58
> new move tool
Wait... what?!
[le check changelog]
Oh, holy heck, that's genius!
That is totally gonna come in handy! I can finally make those on-the-fly adjustments to my coin canister project now!
Heroes are remembered, but Spartans never die. | Proud to be a Halo fan
Taught by Tom Meeks. Small world, eh?
11803.59
Yeessss!!! Thanks Michael - esp for the remove fillets!
11803.60
Fabulous woohoo
11803.61
Fantastic update!
11803.62 In reply to 11803.61
How to add code in MOI3D to run batch files (.bat) in WIN10?
11803.63 In reply to 11803.62
Hi feirui445,
You can set up a shortcut key that will launch a batch file when the key is pressed, is that what you want?
Put this as the "Command" part of the shortcut key (note use additional backslash \ because that is the escape character in javascript):
script: moi.filesystem.shellExecute( 'c:\\scripts\\test.bat' );
Show messages:  1-3  4-23  24-43  44-63  64-83  84-103  104
