V5 beta Sep-17-2025 available now
 1-4  5-24  25-44  45-64  65-84  85-104
11803.25 In reply to 11803.24
Question regarding the fillet options. The ACIS fillet loses the ability to use the G2 and G3 options. Do you plan on keeping the Solids++ or can ACIS produce these options in the future?
11803.26
Thanks for the new beta Michael!
11803.27 In reply to 11803.25
Hi Burr,
I don't have any immediate plans for removing the option to use the old fillets with those options.
It's highly unlikely. But there are a couple of other fillet mechanisms in ACIS though like some face/face operations that I could try out in future versions.
11803.28 In reply to 11803.27
“””””” But there are a couple of other fillet mechanisms in ACIS though like some face/face operations that I could try out in future versions.”””””
Aha! Appears the equivalent of current “blend” where it can fill non connected. And also “hold lines” for continuity control….
The future is bright. Thanks for your time.
Something more speedy and more easy for select only fillets for erase them in some cases!
Like on pyramid first post : https://moi3d.com/forum/index.php?webtag=MOI&msg=11803.1
- Select the Object
- Up Right Menu Details / Faces /Plan = n Faces --> Click "Faces"
- x Planar --> Click "Planar"
- Invert Selection
or even more speedy ! ;) You must have your object alone on the screen! So Select it Invert Selection / Hide)
- Browser "Types"
- Faces / Planar!!! (Right Click on "Planar" for select them )
- Invert Selection
then
Remove Fillets by
Shift + Del key
or Right Click + Shift
or Right Click on Del Button (red "x" Left bottom Bar)
Et voilà! :)
Does it possible to have a script for that ? For ultra speedy users that i am not... due bad memory ! :)
EDITED: 24 Sep 2025 by PILOU
Else for partial fillets remove ! ;)
11803.31 In reply to 11803.29
Hi Pilou, for fewer steps you could do -
"Details..." button, then on the object properties dialog, click "Faces", then Ctrl+click on "Planar" to deselect those.
Or on Scene Browser, Types section, click on the selection dot area for "Faces", then click on selection dot on Faces > Planar to deselect planar faces.
11803.32 In reply to 11803.30
Frenchy.
If you delete just the rounded apex faces you get 'straight corners' on the fillets. ;-)
Martin.
11803.33 In reply to 11803.31
Ah excellent! Another hidden fonctions!
My Moi French Site
11803.34 In reply to 11803.32
@blowlamp
Yep but you don't obtain the same result!
All depend of what do you want! ;)
But maybe Apex is another thing... ? What is exactly ?
And what is your selection ?
11803.35 In reply to 11803.34
Frenchy.
You're showing what I meant in your GIF.
The fact that it's now possible to have straight corners and rounded corners in any combination is a plus as far as I'm concerned. ;-)
The same trick also works with Chamfer. ;-)
Martin.
11803.36 In reply to 11803.1
I've been waiting for this since v3!
Thank you!
11803.37
looks like u are hitting the same overhead as
https://www.youtube.com/watch?v=WvwiH1DOK1M
great improvements, have been asked for a long time !
11803.38
Not a question about the Sep-!7-2025 beta in particular.
I know it's possible to enter fractions such as 17/64" without having to convert to decimal, but is there a formatting rule where I can enter a measurement of something like 4 9/16" directly?
I occasionally get these dimensions in drawings I receive and don't enjoy converting them. ;-)
On my mobile phone calculator, entering 4+9/16 seems to give the right answer.
Martin.
11803.39 In reply to 11803.38
Hi Martin,
Yes, you need to have a unit system set other than "No unit system", and you need a foot (') or inches(") mark in your input.
Then you can use either a space or a hyphen to separate whole inches from the fractional part, like:
4 9/16"
or
4-9/16"
11803.40
Just saw this. Currently installing as I speak, and I am super excited to try this out.
Heroes are remembered, but Spartans never die. | Proud to be a Halo fan
Taught by Tom Meeks. Small world, eh?
11803.41 In reply to 11803.39
Thank you Michael.
It's now working for me if I use a hyphen, but not with a space and of course I was previously using a space.
My unit system is set to millimetres.
Martin.
11803.42 In reply to 11803.20
Amazing and everyday useful ACIS funkcionality, excellent job, Michael!
Thank you.
Mik
11803.43 In reply to 11803.41
Hi Martin,
Which edit field are you typing in ?
11803.44 In reply to 11803.43
Michael.
I click to start the line and immediately begin typing on the numeric keypad and the numbers are displayed in the X,Y,Z box without me clicking on it.
If I click to start the line and then type: 4-7/8" the line is correct.
If I click to start the line and then type: 4 7/8" the line terminates somewhere near the Origin, in fact all lines show similar behaviour whe using the 'space' character.
Martin.
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104
