V5 beta Sep-17-2025 available now
 1-19  20-39  40-59  60-79  …  100-104
I wanted to test moving holes on curved surfaces. It seems to work when cutting the hole in formed solids.
If I create a curved surface, "trim the hole" then shell for thickness, the Move produces an artifact in the hole (For me. Lets see if its reproducible)....
Here is a file
11803.21 In reply to 11803.20
Hi Burr, thanks for the test file. I've had a few cases sent in where closed surfaces in particular are getting mangled similar to what you have here. That is next up for me to work on tuning up.
If you cut the hole after shelling instead of before it, that seems to work better right now (see attached file).
11803.22 In reply to 11803.21
Yes Michael, so far for me it surfaced only when “creating the solid” AFTER the hole trim in the surface…
Noted
One possible thing i noticed but it could be erroneous was picking a point “in the bottom of the hole” to do the move
So normally picking a point at the top surface, but if the point was picked down through the hole at the bottom edge of it… just something to look for. It may not be anything.
Thanks again.
A black hole! :)
My Moi French Site
11803.24 In reply to 11803.21
The corrected file and creation process has the "Move" actually perform faster and smoother also... not just "mangled surface"
Just a note from a fading laptop...
11803.25 In reply to 11803.24
Question regarding the fillet options. The ACIS fillet loses the ability to use the G2 and G3 options. Do you plan on keeping the Solids++ or can ACIS produce these options in the future?
Thanks.
11803.26
Thanks for the new beta Michael!
11803.27 In reply to 11803.25
Hi Burr,
I don't have any immediate plans for removing the option to use the old fillets with those options.
It's highly unlikely. But there are a couple of other fillet mechanisms in ACIS though like some face/face operations that I could try out in future versions.
11803.28 In reply to 11803.27
“””””” But there are a couple of other fillet mechanisms in ACIS though like some face/face operations that I could try out in future versions.”””””
Aha! Appears the equivalent of current “blend” where it can fill non connected. And also “hold lines” for continuity control….
The future is bright. Thanks for your time.
Something more speedy and more easy for select only fillets for erase them in some cases!
Like on pyramid first post : https://moi3d.com/forum/index.php?webtag=MOI&msg=11803.1
- Select the Object
- Up Right Menu Details / Faces /Plan = n Faces --> Click "Faces"
- x Planar --> Click "Planar"
- Invert Selection
or even more speedy ! ;) You must have your object alone on the screen! So Select it Invert Selection / Hide)
- Browser "Types"
- Faces / Planar!!! (Right Click on "Planar" for select them )
- Invert Selection
then
Remove Fillets by
Shift + Del key
or Right Click + Shift
or Right Click on Del Button (red "x" Left bottom Bar)
Et voilà! :)
Does it possible to have a script for that ? For ultra speedy users that i am not... due bad memory ! :)
EDITED: 24 Sep 2025 by PILOU
Else for partial fillets remove ! ;)
11803.31 In reply to 11803.29
Hi Pilou, for fewer steps you could do -
"Details..." button, then on the object properties dialog, click "Faces", then Ctrl+click on "Planar" to deselect those.
Or on Scene Browser, Types section, click on the selection dot area for "Faces", then click on selection dot on Faces > Planar to deselect planar faces.
11803.32 In reply to 11803.30
Frenchy.
If you delete just the rounded apex faces you get 'straight corners' on the fillets. ;-)
Martin.
11803.33 In reply to 11803.31
Ah excellent! Another hidden fonctions!
My Moi French Site
11803.34 In reply to 11803.32
@blowlamp
Yep but you don't obtain the same result!
All depend of what do you want! ;)
But maybe Apex is another thing... ? What is exactly ?
And what is your selection ?
11803.35 In reply to 11803.34
Frenchy.
You're showing what I meant in your GIF.
The fact that it's now possible to have straight corners and rounded corners in any combination is a plus as far as I'm concerned. ;-)
The same trick also works with Chamfer. ;-)
Martin.
11803.36 In reply to 11803.1
I've been waiting for this since v3!
Thank you!
11803.37
looks like u are hitting the same overhead as
https://www.youtube.com/watch?v=WvwiH1DOK1M
great improvements, have been asked for a long time !
11803.38
Not a question about the Sep-!7-2025 beta in particular.
I know it's possible to enter fractions such as 17/64" without having to convert to decimal, but is there a formatting rule where I can enter a measurement of something like 4 9/16" directly?
I occasionally get these dimensions in drawings I receive and don't enjoy converting them. ;-)
On my mobile phone calculator, entering 4+9/16 seems to give the right answer.
Martin.
11803.39 In reply to 11803.38
Hi Martin,
Yes, you need to have a unit system set other than "No unit system", and you need a foot (') or inches(") mark in your input.
Then you can use either a space or a hyphen to separate whole inches from the fractional part, like:
4 9/16"
or
4-9/16"
Show messages:  1-19  20-39  40-59  60-79  80-99  100-104
