splitting existing curve in equal points and trace?
All  1-2  3-6
Rebuild (bottom page)
then ReconstructCurve ? (top page)
You will have just "2 corner points" to resolve! :)
Or seems there is also something to make a curve from Points of Control points... I don't remember :(
change Control Points to Points then make curve from simple points :)
You can also Transform /Array / a Point to the original curve then make the curve by these arrayed points! ;)
EDITED: 19 Sep 2025 by PILOU
11800.4
It may be easier to just use the import as a base and then redraw it like this.
11800.5
Tnx the reconstruct curve seems good.
The tracing works good ....I just want to make it a bit better.
EDITED: 19 Sep 2025 by MATADEM
11800.6 In reply to 11800.5
I use https://svgtrace.com/png-to-svg for tracing and then rebuild command if it's necessary.
Mik
Show messages: All  1-2  3-6
