Is this the best way to do this? blending ?
All  1-4  5-13
11793.5 In reply to 11793.3
Select this profile curve:
Run Construct > Revolve > Rail revolve.
Uncheck "Cap ends" option, and pick this as the rail curve:
Pick revolve axis in Z axis direction:
That should make a well behaved blend then.
11793.6
Tnx I am trying to cut a shape into it as well.
But what is not letting me get my line tangent to the circle for smooth transition?
11793.7 In reply to 11793.6
Hi Matadem,
Is it this curve here?
One problem is that curve and the circle are not on the same plane, they are on different z levels:
11793.8 In reply to 11793.6
You can get them on the same plane by selecting them and then run Transform >Align and pick in the Front view.
Then if you want to edit the curve to be tangent to the circle, create a tangent line from the circle:
The first 2 control points of the curve must be on that line for it to have the same tangent as the circle at that point:
Also if you cut the circle so it is an arc that ends at that spot you can use Construct > Blend like this:
11793.9
tnx...sometimes I get lost in 3d lol
one more thing how would I be above the points and select them?
It seems that when I try to select a bunch of them I select the surface as well...and I need to do them one by one.
also attached sas.3dm is there a more efficient way to do this?
if I remember correctly did some sweep,,,in the middle offset the line both sides..boolean cut then blend...
what would be a more efficient approach?
another way I was thinking of doing this is to cut from a solid block with a "pipe" created by sweep and then fillet the edges...
now the other question I have is if I create a pipe by sweep or other method can I change the size between the start and the finish by a guide or scaling rail?
I saw it somewhere...
Tnx~
EDITED: 7 Sep 2025 by MATADEM
Size: 50.2 KB, Downloaded: 38 times, Dimensions: 707x428px
Size: 70.4 KB, Downloaded: 35 times, Dimensions: 598x511px
11793.10 In reply to 11793.9
Hi Matadem,
You could zoom out to find an empty area to click, or you could hide the surface so it would not be in the way, or you could hold down Shift+Ctrl while starting the window selection.
When Shift+Ctrl is down the first pick will always start a window select, it doesn't need to be on an empty area.
11793.11 In reply to 11793.9
Hi Matadem,
Maybe 2 rail sweep:
Mirror:
Planar:
EDITED: 7 Sep 2025 by MICHAEL GIBSON
11793.12
Thank you!
11793.13 In reply to 11793.9
Hi Matadem,
Yes you can make a pipe shape using one rail sweep and control the cross-sectional size by a scaling rail:
Show messages: All  1-4  5-13
