Is this the best way to do this? blending ?
All  1-9  10-13
11793.10 In reply to 11793.9
Hi Matadem,
> one more thing how would I be above the points and select them?
> It seems that when I try to select a bunch of them I select the surface
> as well...and I need to do them one by one.
You could zoom out to find an empty area to click, or you could hide the surface so it would not be in the way, or you could hold down Shift+Ctrl while starting the window selection.
When Shift+Ctrl is down the first pick will always start a window select, it doesn't need to be on an empty area.
11793.11 In reply to 11793.9
Hi Matadem,
> also attached sas.3dm is there a more efficient way to do this?
Maybe 2 rail sweep:
Mirror:
Planar:
EDITED: 7 Sep 2025 by MICHAEL GIBSON
11793.12
Thank you!
11793.13 In reply to 11793.9
Hi Matadem,
> now the other question I have is if I create a pipe by sweep or other method can I change the
> size between the start and the finish by a guide or scaling rail?
Yes you can make a pipe shape using one rail sweep and control the cross-sectional size by a scaling rail:
Show messages: All  1-9  10-13
