Create solid from copied elements
All  1-3  4-5
11789.4
Hello Michael
thanks for the quick answer.
I see where the problem is, I used offset for the last operation and didn't snap it to the outer surface..
Is there a way to keep a tool live while typing the values? It would be easier to adjust..
Pascal
11789.5 In reply to 11789.4
Hi Pascal,
It depends on the tool but often times things try to finish up when a value is typed in to reduce the number of operations needed to run it.
For curve offset if you are in "Through Point" mode it will finish when you pick the point. If you are in "By distance" mode you can adjust the distance, it won't finish until you pick a point for which side you want.
Show messages: All  1-3  4-5
