How to trim allot of pieces fast?
All  1-4  5-7
11785.5 In reply to 11785.1
Hi Matadem,
> How would I trim these 48 pieces fast? I need to cut out the shapes out of the circle.
With closed curves you can use boolean difference which can speed things up.
Start with the circle selected:
Then run Construct > Boolean > Difference. The prompt will say "Select objects to subtract", select the diamond shapes:
You will then get this result:
11785.6 In reply to 11785.5
Or "Union" gives you the opposite side...
11785.7
The boolean union is that I needed.
but strangly when I was tried this earlier It did not go.
Tnx!
Show messages: All  1-4  5-7
