How to trim allot of pieces fast?
All  1  2-7
In your special case
Maybe you have better time to make one losange module
then make an Radial Array
All makes maybe 2 seconds! :)
PS You must also put your object on the origin and not in the empty space of the galaxy! :)
Because some functions don't like this sort of thing!
11785.3 In reply to 11785.1
Here is one....
11785.4 In reply to 11785.3
Then using a surface and Boolean to generate the edges needed....
11785.5 In reply to 11785.1
Hi Matadem,
> How would I trim these 48 pieces fast? I need to cut out the shapes out of the circle.
With closed curves you can use boolean difference which can speed things up.
Start with the circle selected:
Then run Construct > Boolean > Difference. The prompt will say "Select objects to subtract", select the diamond shapes:
You will then get this result:
11785.6 In reply to 11785.5
Or "Union" gives you the opposite side...
11785.7
The boolean union is that I needed.
but strangly when I was tried this earlier It did not go.
Tnx!
Show messages: All  1  2-7
