How to make a 2D curve follow the shape of a 3D object (like a box) in MoI3D?
11778.1
Hi MoI users,
Let’s say I have a simple 3D object — like a curved box or a bumpy surface made from lofts. Then I have a flat 2D curve (just a line) floating above it on the XY plane.
Is there a way to “drop” the 2D curve onto the 3D object’s surface so that it sticks and follows the shape — like it wraps down due to gravity? Basically, I want the curve to become 3D and conform to the surface, like projecting it straight down in the Z direction.
I tried using the Flow command, but it seems to need a base and target surface with matching UVs, and it distorts the result. I also tried Silhouette, Iso, etc., but none of those do what I want.
Does MoI3D support anything like Rhino’s Project or Fusion 360’s “Project to Surface”? Or is there any workaround to make a curve follow a 3D surface shape like that?
Thanks in advance!
11778.2 In reply to 11778.1
Here is example how I want like Fig 2
Size: 825.4 KB, Downloaded: 77 times, Dimensions: 2363x2363px
11778.3 In reply to 11778.2
Seems exactly that Construct/ function Curve / Project do ?
If you want only top surface just Edit / Separate top surface before launch the Function Project !
Not shown on the animation...
EDITED: 7 Aug 2025 by PILOU
11778.4 In reply to 11778.3
Thank you, Frenchy. But is there any way I can cut just the top part? I figured out my own method — I create a line, then cut with a surface, use “Disconnect” to separate them, and extract the line. But it seems like a multi-step process, so I wanted to see if there’s a quicker solution.
11778.5 In reply to 11778.4
Frenchy's method looks right to me. Just select the surfaces that you want the line to be projected onto by selecting the solid and then clicking again on the surfaces you want the line projected to. There's no need to create an intersecting surface first. You can move the newly created curve to any convenient location or use it where it is.
Martin.
11778.6 In reply to 11778.4
Hi KhoeHuynh,
If you select the top face as the projection target then it will only make a projection there.
You can select face or edge subobjects on a solid by a second click on it. The first click will select the whole solid, and then when the whole solid is selected a second click on it will "drill in" to select faces or edges.
So in your case where you want to project a line onto the top face, select the line:
Then run Construct > Curve > Project.
The prompt in the upper right corner of the window will say "Select projection target".
Select the top face by 2 clicks on the box, the first click will select the whole box and the second click on it will drill in to select just faces or edges:
Then click "Done" or right click in a viewport (shortcut for "Done") and you'll be at the last step in the project command where you can adjust the projection direction. Click "Done" or right click in a viewport again to finish the Project command with this result:
Note that if you want to actually cut the whole box into 2 separate solid chunks you can use boolean difference to do that without needing a separate projection step and if you want to cut just the top face into 2 separate faces you can use Edit > Trim to do that without needing a separate projection step either.
Yep more speedy than my separate solution! :)
My Moi French Site
