Scripting Object Visibility?
 1-12  13-21
11774.13
Hi Michael
The one key hide unhide script is magic thanks
another on my wishlist is to select all objects of a colour (say gold) and run _cvolume 10 on it, copying the volume cm3 to the clipboard
is this possible please for moi ver4
I am always doing this for gold colour
cheers
shayne
11774.14 In reply to 11774.13
Hi shayne,
It would be easiest to do this by making a customized modified version of the _cvolume script.
Please attach the _cvolume .htm and .js files that you currently use and I'll show you what to modify to do those things.
11774.15 In reply to 11774.14
Thanks Michael
uploaded both
cheers Shayne
11774.16 In reply to 11774.15
Hi Shayne, try this version - instead of using selected objects it will use whatever solids are on style = gold whether selected or not.
And copies volume value to the clipboard.
11774.17
Thanks Michael
works perfectly
and I changed my old _CVolume.htm to also copy to the clipboard
cheers
shayne
11774.18
Hi Michael
Similar to hide unhide by style
Is it possible to write script to hide / unhide by object name say 'old'
As I cad new rings next to old designs I constantly have to hide/unhide the old one to clear the screen
Moi Ver 4
kind regards
shayne
11774.19 In reply to 11774.18
Hi shayne,
Try this one:
script: /* Toggle visibility of given name */ var name = 'old'; var item = moi.ui.sceneBrowser.objects.find( name ); if ( item ) { var any_hidden = false; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length && !any_hidden; ++i ) { var obj = objs.item( i ); if ( obj.name == name && obj.hidden ) { any_hidden = true; } var subobjs = obj.getSubObjects(); for ( var j = 0; j < subobjs.length && !any_hidden; ++j ) { var subobj = subobjs.item(j); if ( subobj.name == name && subobj.hidden ) { any_hidden = true; } } } } if ( any_hidden ) { item.alterStatus( 'show' ); } else { item.alterStatus( 'hide' ); }
11774.20
Thanks Michael
I demonstrated and recommended your software to a business associate yesterday , I'm certain he will purchase it.
kind regards
shayne
11774.21 In reply to 11774.20
Thank you shayne! - Michael
Show messages:  1-12  13-21
