Export as Step what is Bsplinesurface
All  1-2  3-7
11773.3 In reply to 11773.1
Hi Matadem, what types of objects are you trying to export, is it stuff like spheres and cylinders?
By default those types of surfaces will export out to a STEP file as BSplineSurfaces.
But you can set an option so spheres will be a SPHERICAL_SURFACE in the STEP file.
To do that go to Options > General > "Edit .ini file" button and inside moi,ini find the section labeled [NURBS Export] and set the option in there WriteAnalyticSurfaces=y
I'm not sure if that is what you're looking for.
11773.4
I was trying to follow this tutroial > https://www.youtube.com/watch?v=U23eLLXuX3o
attached is a pic and the file I made to test it out and the Freecad.
Id can setup this in Vcarve within a minute.
setup tool database is way confusing in Freecad lol.
but I need to learn Freecad for the adaptive toolpath and fusion360 is no option for me with online/cloud stuff.
Tnx!
Size: 123.5 KB, Downloaded: 120 times, Dimensions: 1575x869px
11773.5 In reply to 11773.4
Hi Matadem, so if you set WriteAnalyticSurfaces=y inside moi.ini then MoI should write out PLANE surfaces instead of B_SPLINE_SURFACE_WITH_KNOTS.
That's what I did to make the attached version.
Does this file behave better when you load it into FreeCAD?
11773.6
Ok it is showing some toolpaths so I am going in the right direction with the file you provided.
I am running some more tests tomorrow.
Thanks!
11773.7
Ok it works!
So I am going to play with it some more and do some test cuts....
I always think that Freecad could be a better program if it wasn't free lol.
I always follow its progress...
Thanks!
EDITED: 19 Jul 2025 by MATADEM
Size: 44 KB, Downloaded: 113 times, Dimensions: 812x541px
Show messages: All  1-2  3-7
