UI Customization for newbies
All  1  2-5
11768.2 In reply to 11768.1
Hi Berk, MoI version 5 has a theme function that can be used to customize colors of UI elements.
You can get the v5 beta at https://moi3d.com/beta.htm .
The theme function is under Options > General > "UI Theme".
You can switch there to the dark theme and you can push "Manage themes" to set up your own customized theme.
11768.3 In reply to 11768.2
Got it, thank you!
11768.4
Hi Michael
Is it possible to make a copy og the standard dart theme so i van make a few adjustments
11768.5 In reply to 11768.4
Hi Hep,
Yup, when you create a new theme there is an option for which standard theme it should be based on.
Go to Options > "Manage themes":
Then "Create new theme":
Then it's the "Copy from:" option here:
Show messages: All  1  2-5
