Ask for help
All  1-2  3-12
11759.3 In reply to 11759.2
Thank you for reminding me that the attachment has been uploaded. Thank you.
11759.4 In reply to 11759.3
Curious i see your file on the Box Dialog file but nothing is downloaded inside MOi!
My Moi French Site
11759.5 In reply to 11759.4
working ! - on my side !
It's working now! :)
One Blend Bulge as you want
2 Sweeps
EDITED: 9 Jun 2025 by PILOU
11759.7
Try using the N-sided tool, in the Construct palette.
11759.8 In reply to 11759.1
Hi JINYICOOL, usually it's better to build a solid and then use filleting rather than constructing things one individual surface at a time.
For your case here you can construct it like this:
11759.9 In reply to 11759.1
Hi JINYICOOL, or another possibility is to use Construct > Blend.
To do that, delete this bottom piece:
Restore this plane:
Then you can select these edges and do a Construct > Blend:
11759.10 In reply to 11759.1
11759.11 In reply to 11759.9
Thanks, this gives me a new idea, and I think the mixed curvature result is smoother and more perfect.
11759.12
Dear all,
The NSIDED command will solve this particular problem. It can be found on Construct.
By using a GIF image, I will demonstrate how to do it. It's very easy to do. I hope you are able to accomplish it.
Ray.
Size: 143.6 KB, Downloaded: 150 times, Dimensions: 1342x862px
Size: 213.5 KB, Downloaded: 124 times, Dimensions: 627x417px
Show messages: All  1-2  3-12
