Need Help migrating Moi from PC to Mac
All  1  2-4
11757.2 In reply to 11757.1
Hi binfordboy,
> Actually I want to migrate my customized Moi Version from PC to Mac. I located
> the new Folder for app data under Mac "Library
> /Application Support/Moi" and copied all files from the Windows app data.
> But nothing happened. Do I miss something?
You'll need to close and restart MoI after copying the files over. You'll have some stuff in sub folders to copy too like /commands , /customui , and /startup .
> In some of the files are references like:
> var menu = "moi://appdata/customui/ScriptsSorted1.menu.htm";
> what is the right syntax here under MacOS?
It's the same syntax for both Windows and Mac. When it's using moi://appdata that means "look it up in the appdata folder" which on windows will be %AppData%\Moi and on Mac it will be ~/Library/Application Support/Moi .
So you shouldn't need to change these, they're cross platform.
Maybe check that you've got everything copied including sub folders.
11757.3 In reply to 11757.1
Also double check that you've got the right Library folder on the Mac.
You want the one in your user folder: ~/Library (/Users/<your user name>/Library .
There's another one off of the root at /Library , don't use that one.
11757.4
IT works now. Thank You ver much Michael
EDITED: 7 Jun 2025 by BINFORDBOY
Show messages: All  1  2-4
