Scaling including background images
All  1  2-7
11754.2 In reply to 11754.1
Hi Axel,
> do you think it would be possible to include the background images scaled together with
> whole objects arrangements?
I'm not sure how I could set that up - the Transform > Scale command handles scaling objects and background images are not regular objects.
I could set up a script that could scale the background images to a given scale factor, would that be useful?
11754.3 In reply to 11754.2
I suspected that maybe the feature "embed image data in 3dm file" could be extended to that idea to scale the images together with the curves/objects.
If I have several images as background images and want to scale the whole file then I would have to scale each image single by single and align to the exact position. There could be always little discrepancies after manual scaling each image.
Such a script I guess would be of help. I don't know if the image would need to be shifted to its original position after the scale.
Thank you,
Axel
11754.4 In reply to 11754.3
Hi Axel, here's a TransformBackgroundImages script which has a move function and a scale function which will transform all background images together.
11754.5 In reply to 11754.4
many thanks!!
Thats really great, because it reduces discrepancies and saves time.
One request: is it possible to get it with undo ability?
Best regards,
Axel
11754.6 In reply to 11754.5
Hi Axel,
Unfortunately since background images are separate from regular objects there isn't the same undo infrastructure for them. So it's complicated for a script like this to support undo on them.
11754.7 In reply to 11754.6
thanks anyway for that script!
Best regards,
Axel
Show messages: All  1  2-7
