StraightSnapLineColor V4vsV5 inconsistency
All  1-3  4-5
11748.4 In reply to 11748.3
Hi Mik,
> The most clear solution IMO would be to have this setting, ie StraightSnapLineColor in Theme manager.
So there is a theme setting STRAIGHT_SNAP_LINE_ARGB_COLOR for this but to edit it you need to edit the theme's defines.inc file in a text editor. There is not yet a UI control for editing a color that includes transparency.
That theme color will only be used if the value in moi.ini has the default value which is
StraightSnapLineColor=103,0,0,0
If you've customized that value in moi.ini then it will use your custom value instead of the theme's so it will have compatibility with previous versions.
I will set up a STRAIGHT_SNAP_LINE_ARGB_COLOR2 which can optionally be present in the theme's defines.inc file to directly specify the second color to be used for a dark background theme instead of inversion.
11748.5 In reply to 11748.4
Yes, I understood, I set in moi.ini file StraightSnapLineColor=103,0,0,0 and in defines.inc file, which correspond to my current theme, STRAIGHT_SNAP_LINE_ARGB_COLOR #B0FFFF00 for yellow color.
The result is yellow dashed (slightly transparent) and blue gap, this is practically same result if I set in moi.ini StraightSnapLineColor=255,255,255,0
No problem, I will wait for STRAIGHT_SNAP_LINE_ARGB_COLOR2.
Mik
Show messages: All  1-3  4-5
