Script request
All  1-4  5-12
11746.5
Hi Michael
That is brilliant thank you so much .
It will save me countless time every day
cheers
shayne
11746.6 In reply to 11746.4
Hi Michal
is it possible at the end of the script to have it copy the 3dm filename into the clipboard also ?
cheers
shayne
11746.7 In reply to 11746.6
Hi shayne,
Yes, try this one:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); } moi.copyTextToClipboard( filename ); }
11746.8
Hi Michael
It copied the full path c:\to print\filename.stl
I just need the filename only if that is possible without any .stl or .3dm
shayne
11746.9 In reply to 11746.8
Hi shayne, try this one:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { var basename = filename.substr( 0, index ); filename = basename + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
11746.10 In reply to 11746.9
Thanks Michael
it errors
ReferenceError: Can't find variable: basename
line 1
1: >> var folder = 'D:\\To Print Morris and Watson\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
If its too hard to do don't spend any time on it
cheers
shayne
11746.11 In reply to 11746.10
Hi shayne,
> it errors
It looks like you only copied the last piece of the above script?
You are missing this part in the new version above:
Try copying the entire script from above not just the ending part.
11746.12
Works perfect thanks shayne
Show messages: All  1-4  5-12
