Modeling a thread with tapered end
All  1-9  10-12
11745.10 In reply to 11745.9
I'm not sure what I'm not understanding...
I'm a "polygon modeler", so I'm not used to all the difficulties with Fillets and Chamfers, and the "broken edges" that I experience when learning modeling in MoI. There must be something fundamental that I'm missing because I really struggle so often when trying to add Chamfers or Fillets to my objects.
In the attached examples (3DM file included), I start with the thin joined surfaces. They look clean to me… I offset this using the "Shell" command, and now this is a "solid". When I select the highlighted edges, I can perform a partial Fillet on the edge (but it's limited to only half the thickness of the shell). And the Chamfer doesn't work at all?
What is it that I'm missing? Also, is there some kind of "optimize" command that cleans my model from corrupt edges and welds edges within a certain distance?
Size: 306 KB, Downloaded: 137 times, Dimensions: 1400x483px
Size: 422.3 KB, Downloaded: 133 times, Dimensions: 1400x806px
Size: 363.4 KB, Downloaded: 126 times, Dimensions: 1400x788px
11745.11
I wouldn't shell the separate parts. If you look at the profile of the curved interior area the shell pushes that portion out. I would revolve the whole top part, shell that then cut the curve interior away. that guarantees a clean profile. At that point you can chamfer/fillet the edge.
On a side note, shell has a similar effect in poly modelers as well.
EDITED: 26 May 2025 by VAL2
11745.12 In reply to 11745.10
Hi Frederick, sorry you're having difficulty.
Yes, CAD modeling tends to be more finicky than poly modeling. That's generally because CAD modeling is trying to generate geometry that accurately represents shapes and not just making a "looks like it" approximation.
There are some tips here for people coming from a poly modeling background:
https://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
The main concept is in CAD modeling you want to build a simplified extended shape and then cut that up using booleans.
For your case here that means the initial target that you want to get to is this:
You can use Shell to get this:
Then the largest fillets:
Boolean difference with a cutting line to cut it in half:
2nd largest fillets:
So note that once you have formed the initial solid it's good to try and keep working on it as a solid if possible because you can then use booleans to cut pieces.
Show messages: All  1-9  10-12
