Proportional Editing for Moi's Organic Surface
 1-4  5-24  25-44  45-47
11741.25 In reply to 11741.24
OP's original image....
11741.26
Hi BurrMan, thank you very much for the videos! I subscribed to your channel right after watching them.
I understood the first two videos quite well, and I definitely learned something important about enabling and disabling history — I never realized it could be that powerful.
However, I didn’t quite understand the third one, especially regarding proportional editing. Are you saying that deforming is the only way to mimic Blender's proportional editing?
11741.27 In reply to 11741.22
Ahh… this one!
Now I understand the purpose of your third video — that’s a very creative way of thinking.
I’ll give it a try and explore further possibilities.
Thank you so much, BurrMan!
11741.28 In reply to 11741.26
“””””” However, I didn’t quite understand the third one””””””
The first 2 showed “if you were the creator” and keeping your curves to use with history (5 point curve for 500 point surface) you can get creative to “kindof” get what you want by moving a mass of points smoothy with just 1 pick point.
The 3rd one was me thinking “how do i apply it if YOU send me a surface with 500 points and NO CURVES.
So the 3rd vid is showing using flow and using a DUPLICATE of the mass point surface. In theory to get the “less points” to use.
But as an afterthought, i would still need to build a surface to gain access. I would probably attempt this with iso curves on the surface then rebuilding the curves to get simple curves to use. (If i could do that, that would eliminate FLOW!!)
So you got something out of it! We (and others) can explore more this for “scenarios” to see if its actually viable or false. Certainly not a replacement for poly soft selection but maybe a good lick in the toolbag?
Let me know…
11741.29 In reply to 11741.28
Sometimes, I need to make a minor modification to an organic surface created with MoI tools like Network, Loft, Sweep, Blend, etc. For example, from a surface blended between two edges, I might want to add a slight "bump" in the middle. In such cases, the quickest (and smoothest) way is often to edit the resulting surface points directly.
However, editing them one by one can be a tedious task — and that’s why I brought up the idea of proportional editing in my initial post, in the spirit of “organic surface explorations.”
Just like in Blender’s proportional editing, the idea is: when I pull a control point along its normal, the surrounding control points follow as well, but to a lesser extent — in a proportional way. That way, I wouldn’t need to manually adjust each point just to create a smooth bump. Doing it point-by-point would be quite impractical — especially, as you demonstrated, when an organic surface might contain hundreds of control points.
Your third video is brilliant. I learned something really valuable from it!
That said, for purposes like the one I illustrated above, the method still feels a bit unintuitive — at least for quick, exploratory shaping.
Cheers!
11741.30 In reply to 11741.25
Your third video with surface is like my last video and the use of Flow... :)
My Moi French Site
11741.31 In reply to 11741.30
Very different….
11741.32
Thanks for the other recommend, Pilou! Another much easier-to-use interface than Blender. :D
I'm still not quite sure I understand the techniques from your videos, Burrman, but I'll watch them a few more times and maybe it will become clear. Thanks very much for taking the time to show it all.
11741.33 In reply to 11741.32
Where are you stuck in the Burman videos ?
First is just move the Control points of the curves!
Don't kill the original curve when you have made a function! (here an extrusion)
About the Flow Function! You can take any volumes, surface etc...
Copy the "start" under surface
The littel trick is to select the object result then call the History! ;) Not intuitive but that works fine!
You can add points on the surface target before the Flow but object will be deformed...
(don't kill or modify the original Object and surface)
No more simple and speedy! (and i have an more 12 years old latop! ;)
EDITED: 27 May 2025 by PILOU
11741.34 In reply to 11741.33
Oooooooooooohhhhh! I *think* I get it now. I've literally never used the "History" function up until now. I still can't quite understand how (in your screenshot/animated examples) the flat surface full of points is generated beneath the extruded shape. I can see a flat load of points when I select/add points to a flat shape, but they don't form a solid flat sheet/object like in your example and I'm not sure how to make it so. Is there something I'm missing?
Thank you very much for taking the time to show/explain it nonetheless, pal. :)
11741.35 In reply to 11741.34
The secret! ;)
You can't add points to several surfaces in the same time!
So you must copy one surface with its adding points made! As shown in my previous video! :)
Else for general case for deform a complex volume...by face...don't move the perimeter's points !
For the complex volume above the rectangular surface it's just the Flow function! :)
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
You can take any surface as start base! Planar or not!
so a rectangular, circular as a disc, a bump etc...
Better if you take something like your base object! Take the copy of the bottom object can be also cool!
You can also take a simple line like following...
EDITED: 30 May 2025 by PILOU
Show only points can be very design! :) from the object above...
My Moi French Site
11741.37
While we’re on the topic — I remember seeing somewhere in this forum a command that can rebuild a surface’s control points, significantly reducing their number without altering the surface itself. I’ve tried searching for it, but I can’t recall the right keyword.
Could anyone kindly point me to the correct command? I’d really appreciate it. Thank you in advance!
11741.38 In reply to 11741.37
Hi Elang,
Check out Mo's RebuildSurface script here:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11191.1
11741.39 In reply to 11741.38
Yes, that’s exactly what I was looking for.
Thank you so much, Michael!
11741.40 In reply to 11741.35
Thanks again, Pilou. I still don't quite understand, but I'll think about it all going forward and maybe it'll come to me. :D
11741.41 In reply to 11741.40
Seems my videos explicite! :)
in what exactly stage are you stuked ?
For deform an entiere volume use Flow with a surface more or less "add pointed" ! :)
(and with history if you want numerous advanced deformations)
For deform localy something use only a surface / Face separated where you add points...
11741.42 In reply to 11741.41
Ah, thank you. :) I understand all the Deform stuff perfectly - but whatever the thing being talked about where the 'History' is used in a new way . . . . unless I've just misunderstood and it's how my History has just been working automatically, I don't get it at all. It seemed like it was something to do with editing points on an original/simple surface and having them take effect on a related/more complex one, but no matter how many times I watched the GIFs and videos you guys made, I couldn't make sense of it.
It's OK, though. If I need to understand it, I'm sure it will come to me eventually. If not, it's no big deal. The world of 3D modelling is confusing enough and my brain is just about functioning without melting, as it is. :D Thank you, anyway.
11741.43 In reply to 11741.42
You just modify the Control Points of the base surface!
Yes The base surface "modified" modifies Volumes surfaces etc... above it!
History is not automatically enabled on each function!
Here the not intuitive thing of the (mine) method is that you select the volume(s) "Flowed" one time!!! for enable the History! :)
And all after works like a charm!
You move the Points of the base surface, and all above are modified! :)
Many time during the session if you don't touch the letters & surface for other modifications...
EDITED: 4 Jun 2025 by PILOU
11741.44 In reply to 11741.42
Hi Mike,
The “original discussion” was a guy who asked for proportional editing or soft selection (whatever you want to call it. The andwer is thats better done in a poly app which actually edits that way.
I pointed out he could “kindof” acheive it by not overlooking MoI’s history mechanism. (Some people just hadnt explored that yet)
Basically a simple Network curve setup can have curves with a very small amount of points that create a surface with 500 or a thousand points. So if YOU create the surface and keep the curves around, you can enable history and when you move “1 point on your construction curve” you are deforming 50 or 100 points in a somewhat “soft selection” type way. You can even add points to the original curves and do different things like “crease” or “harder” selection!
Finally, what if you have a surface with 2000 points and “no original curves with only 5 points”
I attempted to show a way to solve this. You could re create the surface to some type of degree using isocurves on the complex surface, then rebuild to get simple curves for soft selection, then incorporate flow to flow your complex surface from your new rebuild geometry and get a new object that can be edited by your new soft selection, without altering the intent.
Its not regular “flow from a surface” like the distraction is confusing you on. Its not “how to deform an object”. If you start thinking about THAT, then you have missed the topic….
Show messages:  1-4  5-24  25-44  45-47
