Lose scripts each time I download the latest version
All  1-2  3-4
11734.3 In reply to 11734.1
Hi Gunter, starting with version 4 you can install the scripts to the Moi appdata commands folder instead of into the installed program's commands folder.
When you do it that way you won't need to re-install with new versions.
There's some more detailed info here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
11734.4 In reply to 11734.1
HI gunter
我想你需要它:https://moi3d.com/forum/messages.php?webtag=MOI&msg=10353.1,这样你可以将脚本独立安装在C:\Users\your name\AppData\Roaming\Moi\commands并即刻调用它们。这样在安装新版本时只需要安装Extras脚本就能同步在新版本中。(This way, you can install the script independently in C: \ Users \ your name \ AppData \ Roaming \ Moi \ commands and call them immediately. This way, when installing a new version, only the Extras script needs to be installed to synchronize with the new version.)
Show messages: All  1-2  3-4
