Automatic center when selecting an item?
All  1-12  13-14
11718.13 In reply to 11718.12
Hi Matadem, thanks for posting the file.
Inside the Loft command, you can set the option for "Profiles: Exact" :
With that set, you should then get center snaps on the top and bottom faces, can you confirm?
11718.14
Yes that did it!
When you draw for long hours every little bit that can save time helps.
Thank you!
Show messages: All  1-12  13-14
