Automatic center when selecting an item?
All
1-11
12-14
Matadem
25 Apr 2025 (12 of 14)
11718.12
All are lofted.
the first is lofted with the bottom extruded, curves deleted, boolean union
the second is lofted curves deleted
the 3d is lofted and left as is and here you can pickup the center.
Tnx.
loftgear2.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
25 Apr 2025 (13 of 14)
11718.13
In reply to
11718.12
Hi Matadem, thanks for posting the file.
Inside the Loft command, you can set the option for "Profiles: Exact" :
With that set, you should then get center snaps on the top and bottom faces, can you confirm?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Matadem
26 Apr 2025 (14 of 14)
11718.14
Yes that did it!
When you draw for long hours every little bit that can save time helps.
Thank you!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-11
12-14
