Seeking function
All  1-3  4-6
11709.4 In reply to 11709.3
Hi Frederick,
> The question: when setting the hidden property to TRUE does that automatically
> set the hidden property for all sub-objects?
It depends on the object type - on a group setting group.hidden = true will set hidden = true on the immediate children of the group.
On other objects no - on a solid for example setting solid_obj.hidden = true does not set .hidden = true on all of its face and edge sub-objects.
A sub object is effectively hidden if either it or any of its parent objects has hidden == true.
11709.5 In reply to 11709.4
Also re:
> When setting the hidden property to FALSE I found that I had to do the same
> for all sub-objects for the object to be displayed.
Shouldn't normally be needed to do that unless you've set hidden = true on all the sub objects yourself.
For example, start with a blank scene, draw a box, and hide it (using regular UI).
If you then run this script it should show the box, by only setting .hidden = false on the top level box object only:
var box = moi.geometryDatabase.getObjects().item(0); box.hidden = false;
11709.6 In reply to 11709.5
Thanks for all the information about how the hidden property works.
I will re-visit my code and see what I did wrong, to require "un-hiding" all of the sub-objects.
You should setup a "tip jar" for all of us folks that learn so much from you.
Frederick
Show messages: All  1-3  4-6
