Numeric Keypad
 1-19  20-24
11705.20 In reply to 11705.19
> A short cut under the mouse near the object...
Sorry, no that's not good.
Like I mentioned previously it's a general goal for the MOI UI to avoid putting UI elements directly floating over the viewport since they add clutter.
It would be easy for it to accidentally get triggered when you trying to do something else like select an edge or a face.
11705.21 In reply to 11705.20
Ok no problem :)
I suppose a floating windows inside the "desk" is not possible ? like the numeric key board exemple above ...
11705.22 In reply to 11705.21
Sorry I don't understand this part.
You mean the one you showed here?
http://moi3d.com/forum/index.php?webtag=MOI&msg=11705.17
That seems like it would be pretty strange.
11705.23 In reply to 11705.22
Yes for resolve the little problem of number y, z readability! :)
11705.24 In reply to 11705.23
Hi Pilou, I don't think it's needed.
When you open up the Edit size menu the numpad will not be showing yet so you can see all values right then.
It's only when you click on a field that it will pop up, and if you decide you want to see the other values after that just close the popup.
You can close it pushing the Esc key, clicking the red X close button, or clicking anywhere outside of it.
Show messages:  1-19  20-24
