Numeric Keypad
 1  2-21  22-24
11705.2 In reply to 11705.1
Hi MindSet, do you mean you want a shortcut key that opens the "Edit size" menu as if you had clicked on it?
11705.3 In reply to 11705.2
Thank you, Michael.
Yes, I want the Numeric Input dialog to facilitate the Edit Size dialog.
It currently never does this for me.
Generally, I prefer to work via the mouse, rather than the keyboard.
Moi Bueno
MindSet
11705.4 In reply to 11705.1
You dont need a shortcut but a free program called KeySharp.
In that way you unlock the full potential of the Moi3D-program.
And can use Numlock device as a numeric input by reprogram the Num-lock USB to
function as a "elonged arm" for Moi3D and almost any other program.
The program is called KeySharp and let you program the numeric input.
By activating the numlock you also activating the USB-input device (or any other device you
program with KeySharp).
You can offcourse use it with games, illustrator,photoshop also and
SpeedCrunch (with Moi3D) in tandem.
Offcourse there is very expensive num-lock devices (num-pads)
but any ordinary will do the job with KeySharp.
Bästa hälsningar!
11705.5 In reply to 11705.3
Is there an issue that prevents Moi from using the Numeric Keypad with the Edit Size dialog?
Moi Bueno
MindSet
11705.6 In reply to 11705.5
Hi MindSet, that particular area of the UI is designed to be keyboard focused instead of using the numpad pop up.
If I remember right it was seeming a little strange to have the numpad hanging off of another small sized pop up menu.
I've attached a modified version of the EditSizeMenu.htm file which should use the numpad popup now, put it in place of the current version in the install's UI folder.
11705.7 In reply to 11705.6
Hey Michael,
Yeah!
I thoroughly appreciate your accommodation because I really prefer using the mouse.
Thank you so very much.
Moi Bueno,
Mindset
EDITED: 18 Apr 2025 by IGNITER
Why the Numeric Key Pad is not "Floating" ?
11705.9 In reply to 11705.8
Sorry, I'm not understanding this, can you show an example of "floating" ?
Thanks, - Michael
11705.10 In reply to 11705.9
Moving over the sceen...
My Moi French Site
11705.11 In reply to 11705.10
Hi Pilou, what would be the purpose of that?
11705.12 In reply to 11705.11
On the particular case above release place for input value with mouse
else in general case avoid to cross the screen for in input value when you have a big monitor!
Just put your "numeric keyboard" near your object on the screen...input values! :)
It's not vital just extreme confort! :)
My Moi French Site
11705.13 In reply to 11705.12
It pops up when you click in a numeric entry field. If it were to show up some
long distance away from the field you just clicked on that would be much more
mouse travel than it is currently.
Also there's an overall focus in the UI design to not have too many things floating
over top of the viewport since that kind of "clutter" can get in the way of seeing
the actual objects.
11705.14 In reply to 11705.12
Hi Pilou, here's an example - when you're in the Arc center command, there is a
field you can use to set the length of the arc instead of the angle:
When you click on that field, the numpad panel will pop up right next to the
control you just clicked:
Why would you want to have the numpad pop up far away from
the control you just clicked?
Just confort! :)
My Moi French Site
11705.16 In reply to 11705.15
Hi Pilou, if the "Floating edit size" dialog you show would be shown by clicking on the size line like it currently is, that would mean you would have to move your mouse all the way over to the right hand side of your screen to make it show, then all the way back across the screen again.
Or do you mean the dialog would always be showing? It's not practical for every type of pop up menu to be all be shown at the same time, the window would be covered in floating UI pieces.
11705.17 In reply to 11705.16
Will be not seen all the time...Closed when you press Done or OK ! :)
In fact there are 2 things
: the numeric kay pad hide the numeric values (that you resolve by killing the keybaord from i have seen in loading your modified EditSizeMenu! :)
: floating windows of any thing... who is not of course the general case actually!
Else more like this... :) in fact must 2 windows the General Edit window itelf and the Numeric Cases + Key board! :)
Here only the Keyboard
11705.18 In reply to 11705.17
And how would you open it?
11705.19 In reply to 11705.18
A short cut under the mouse near the object...
Ps But in the case of this Image... http://moi3d.com/forum/index.php?webtag=MOI&msg=11705.15
I can also move all the volume screen near the actual right desk ! ;)
Click MouseWheel + Move... maybe avoid all the Floating windows! ;)
rest only the numeric key board problem if we want keep it and visible x,y,z! :)
11705.20 In reply to 11705.19
Sorry, no that's not good.
Like I mentioned previously it's a general goal for the MOI UI to avoid putting UI elements directly floating over the viewport since they add clutter.
It would be easy for it to accidentally get triggered when you trying to do something else like select an edge or a face.
11705.21 In reply to 11705.20
Ok no problem :)
I suppose a floating windows inside the "desk" is not possible ? like the numeric key board exemple above ...
Show messages:  1  2-21  22-24
