Numeric Keypad
 1-16  17-24
11705.17 In reply to 11705.16
Will be not seen all the time...Closed when you press Done or OK ! :)
In fact there are 2 things
: the numeric kay pad hide the numeric values (that you resolve by killing the keybaord from i have seen in loading your modified EditSizeMenu! :)
: floating windows of any thing... who is not of course the general case actually!
Else more like this... :) in fact must 2 windows the General Edit window itelf and the Numeric Cases + Key board! :)
Here only the Keyboard
11705.18 In reply to 11705.17
And how would you open it?
11705.19 In reply to 11705.18
A short cut under the mouse near the object...
Ps But in the case of this Image... http://moi3d.com/forum/index.php?webtag=MOI&msg=11705.15
I can also move all the volume screen near the actual right desk ! ;)
Click MouseWheel + Move... maybe avoid all the Floating windows! ;)
rest only the numeric key board problem if we want keep it and visible x,y,z! :)
11705.20 In reply to 11705.19
Sorry, no that's not good.
Like I mentioned previously it's a general goal for the MOI UI to avoid putting UI elements directly floating over the viewport since they add clutter.
It would be easy for it to accidentally get triggered when you trying to do something else like select an edge or a face.
11705.21 In reply to 11705.20
Ok no problem :)
I suppose a floating windows inside the "desk" is not possible ? like the numeric key board exemple above ...
11705.22 In reply to 11705.21
Sorry I don't understand this part.
You mean the one you showed here?
http://moi3d.com/forum/index.php?webtag=MOI&msg=11705.17
That seems like it would be pretty strange.
11705.23 In reply to 11705.22
Yes for resolve the little problem of number y, z readability! :)
11705.24 In reply to 11705.23
Hi Pilou, I don't think it's needed.
When you open up the Edit size menu the numpad will not be showing yet so you can see all values right then.
It's only when you click on a field that it will pop up, and if you decide you want to see the other values after that just close the popup.
You can close it pushing the Esc key, clicking the red X close button, or clicking anywhere outside of it.
Show messages:  1-16  17-24
