Could it be done?
All  1-13  14-15
11704.14 In reply to 11704.8
Hi Peer,
> Is there a way to copy an object from one window and paste it at the cplane origin in
> another window? The default behavior is to paste at world origin.
It looks like you've already got the answer from Burr, but just to be sure - yes you can do that by using the PastePart command instead of regular Paste.
In your source window if you have a cplane set up at the object's base position you can use regular copy (Ctrl+C on windows/Cmd+C on mac) in the source window, and then in the target window use PastePart (Ctrl+Shift+V on Windows/Cmd+Shift+V on Mac) (or also right click on Edit > Paste button) instead of regular Paste.
With PastePart you will then be in the orientation picker just like the ImportPart command, you can type 0 <enter> to pick the target location at the cplane origin.
If you do not already have the cplane set in your source window you can use CopyClipboardWithOrigin (Ctrl+Shift+C on windows/Cmd+Shift+C on mac) (or right click on Edit > Copy button) instead of regular copy which will let you pick a point to use as the copied part's base position instead of using the current cplane origin.
EDITED: 11 Apr 2025 by MICHAEL GIBSON
11704.15 In reply to 11704.14
Wow Michael thanks for schooling my on these additional nuggets! I didn't know about 0 in the xyz box specifying the cplane origin or that regular copy is aware of the cplane origin. You got me to go back to the documentation and learn a few other things about the xyz box.
- Peer
Show messages: All  1-13  14-15
